I think you meant to say current and not power.davidsmith wrote:. This means that a "wire" of a given size that made up of many smaller strands can carry more power than a solid wire - simply because the stranded wire has more surface area. This is one reason why battery cables in your car and welding cables are made up of many very fine strands of smaller wire - it allows them to safely carry more power with less of that power being dissipated as heat.
engine room lights
- Commissionpoint
Re: Wire Size
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
Commander 351 Ford (PCM)
1:1 Borg Warner
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
Since this is a marine forum, we're talking stranded wire only. I know that a given size wire can handle a given amount of current however it can only carry it for a certain distance before a load fails to opperate properly and safely. For the benefit of those electrically challenged that read threads like this one, I don't think it's a good idea to simply throw out current capacities without mentioning distance limitations. Without mentioning distances, someone reading this may think it's ok to assemble a 50 foot run with the same AWG stated for 15 amps that maxes safe delivery at 10 feet. IMO, we shouldn't mention one without the other....they go hand in hand.
- Commissionpoint
I dunno if this has been posted before, but its a pretty decent basic source of information.
http://www.cncphotoalbum.com/doityourse ... wiring.htm
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
That's a good example. Pretty much the same charts I use. Depending on where you get such charts, numbers vary slightly but negligible. Again, the key is the length of the circuit not to mention how, for what, and where it's being run.
That is the BEST bet when not sure!prowlersfish wrote:And there is nothing wrong with going with a heavier gage wire then what is called for .
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
