Chrysler 440/adjustable oil presssure
Freddy
Post by Freddy »
So I went down to the boat today and visually inspected/verified that the new oil pump does not have the adjustment screw in the relief valve. Definitely keeping it that way. I haven't found anything regarding higher pressure during break in but I'm still researching that in the Buick and Pontiac forums I have some experience with.
I'll keep you all posted...
1976 F30 Model 303
jefflaw35
Post by jefflaw35 »
all of this scares me, i want to replace the oil pump in my new to me long block chy 318. i will be shaking as i pull the old out and put the new, not rebuilt i hope in.
Freddy wrote:..... When the boatyard re-installed the motor it was run for just a few seconds to make sure the dist. wasn't in backwards and the plug wires were in the right places. The motor started right up and ran perfectly but the mechanic noted the oil pressure was high for idle(he didn't specify what the reading was).......
IMO, it's always best to run and test a rebuild on the floor before being installed. It would have been easier to deal with a possible rebuild issue that way before going through all the trouble of installing then possibly removing again to remedy. Once you're happy that all is running well on the floor, and reading are normal, then install.
