Fix or Replace my Dinghy Motor-REALLY NEED ADVICE !
gettaway
Post by gettaway »
I have a 11 APEX rib and a Nissan 8 HP 2 stroke, it's not fast out of the hole, but she hauls @$$ once on plane, with me and two teenagers
1984 Silverton 37C
Silver Lining
Scott
I'm going to do some more work on my antique.
The powerhead does run and start great !
However...
Found my lower unit is leaking gear lube out of the seal behind the prop.
Had very little lube in it and what was added leaked out.
additionally
The roller bearing at the base of the water pump was rusty.
It's a shame, the unit starts and runs nicely
Perhaps there is a used Yamaha 8 hp 2 stroke in my future....
Bearings are rusted because of the lack of oil, most likey had water in it if seal leaking, that's why the gear lube should be checked and replaced every season, and the drive pressurized. The seal is a maintenance item in every drive/make that will leak if not maintained. This will not change with a new unit, just buy you some more time.
jddens
Post by jddens »
This has been a good informative thread (as usual). Got me doing some research and I've discovered most 2 stroke 15hp weight the same as the 9.9s. I was looking for a 9.9 but am going to check out a rude 15hp this morning. It will go on a 11 foot inflatable rated for 15hp.
Is any one familiar with the brand "Saturn" inflatable? Seem reasonably priced and look to be decent quality.....Thanks.....John
1998 Kawasaki ZXi 1100
Mike Kulp
Post by Mike Kulp »
You are right about the weight from a 9.9 to a 15 my friend has a 9.9 johnson and he checked with the dealer and they told him all he has to do is buy the carb for a 15 johnson and he has 15 hp.
Mike 1986 10 Meter mid cabin
jddens wrote:This has been a good informative thread (as usual). Got me doing some research and I've discovered most 2 stroke 15hp weight the same as the 9.9s. I was looking for a 9.9 but am going to check out a rude 15hp this morning. It will go on a 11 foot inflatable rated for 15hp.
avoid plastic or PVC
go with HYPALON material
Lawman
Post by Lawman »
Is the cast housing split? If so, smear some JB Weld on it and let it dry ??!
1973 F30 Clean Machine
' Goomar '
(Italian for 'my mistress')
myakka
Post by myakka »
"avoid plastic or PVC
go with HYPALON material"
I agree. My Zodiac(PVC) only lasted 10 years. That seems to be an average lifespan for them.
Squall sailing dingy
18 outrage(Sold)
25 Trojan(still own, until current user finishes paying me)
Dauntless 220
Commissionpoint
Post by Commissionpoint »
My Achilles has an April 1983 manufacture date. It will be 30 years old soon. I'd say its in real good shape after all of these years, it was given to me on my 8th birthday, and I have used the $hit out of it. The motor needed work this past spring and thats the first money that got spent on the set since it was bought new almost 30 years ago. I couldn't possibly guess at the hours. Many thousands.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
Commander 351 Ford (PCM)
1:1 Borg Warner
