Rpm gauge hook up on 318 F25 ?
gordd
Re: Rpm gauge hook up on 318 F25 ?
Post by gordd »
The Dog House wrote: If you can determine that the wire at the engine is the same wire that is connected to the tachometer, it may be as simple as connecting the yellow wire at your engine to the distributor side of the coil.
It is same wire connected to tach via the fuse panel .. it just to short to connect to coil why wondered where else previous owner may have had it connected as it is electric start . What mean there is no points system in cap
