Head question
Muskokan345
Re: Head question
Post by Muskokan345 »
Yeah, the head is the standard W.M. about $170 up here in Can, my boat only has 1 fuel tank that is mounted transversely behind the engine, and the water tank is mounted on the Port side, so I had a ton of room on the Stb side of the boat, I managed to wiggle in a 15 gal tank. Tank was about $150, waste hose is about $9/ft, I used the old vent hose, although I am monitoring that and my replace it too. The worst part is that the new head required that I drill a hole in the boat and install a seacock. I tried it with the pressure system but the bowl fills way too quickly. Fortunately I was on the hard while I was making the change over. Oh! one more thing...you need to remove the bowl from the holding tank of your existing head to remove it from the boat!!
1986 F26
