Well, it looks like this project is now on hold until the fall. I have the fresh water tank assembled and the black water tank ready to weld but at this point the job seems to have become much bigger than originally planned. While I was at the boat last week, preparing it for the tank swap, I realized that this job was only going to lead to several other small jobs. In order to replace the tanks, the exhaust tubes and manifolds must be removed to gain access. While the manifolds are out, this would be the perfect time to move the fresh water pump, accumulator, shower sump, A/C pump and all of the hoses to locations that are easier to gain access to when service is required. Anyone that owns an F-26 with a fiberglass cockpit knows what I'm talking about. So the plan is now to move all of the above to the aft bulkhead under the rear access panel. Also, with everything out of the way, it'll be a good time to apply a fresh coat of Bilgekote. One job leads to another. Since I missed out on last season completely and all of these jobs would probably keep me on the hard until mid July, I decided that this is just not acceptable.
So as for this season, I have the exhaust manifold removed from the right bank to gain access to the black water tank's fowl smelling pump out hose so that I can replace it. When I re-assemble the manifold, I will be replacing the exhaust tubes with Blue Trident exhaust components. I'm adding a few elbows to change the shape of the 2 into 1 system to gain better access to my house bank and my shaft seal. See, again one job leads to another.
A lack of fore sight.
When this boat was going thru its stringers up restoration back in 2000, I replaced all of the plumbing to the pumps but left them located in their original positions. I never thought that down the road I might not be flexible enough to access these positions for servicing. This may be something to think about for those who plan on hanging on the their boats long term.
