Remote oil filters
jordan
Re: Remote oil filters
Post by jordan »
Looks great Larry, that's what I in mind. Didn't visualize it to look that good though!
Thanks for the pics, Jim
SHEGAVEIN (F-32)
Capt. Jim Jordan
Post by larryeddington »
Just a note, if you noticed the spark plug wires run through insulated "adels" fastened to the exhaust manifold which had threaded holes, seem like they were there for such an install. Normally the 318 wires run between the valve cover and manifold which IMO was bad as the manifold has to be removed to re-wire or the sparkplug wires must be made in situ. I used small block chevy 8 mm wires and re routed using the aircraft quality "adels". IMO a better idea. :) One could use a really pretty set of wires with color, such as ACCEL I suppose. If I ever change them will do so.
"Small block chev ,Larry????---- oh the HORROR---- those mopars will know. Lol--- Mike
not a chance, aftermarket wires. :lol:
