Page 2 of 3
Re: can you guys tell me about your nuts?
Posted: Wed Apr 30, 2014 7:52 pm
by Commissionpoint
prowlersfish wrote:
Roll your eyes at me all you want. We can just agree to disagree. AGAIN.
No need to be snarky with me. I'm nice to you.
Posted: Wed Apr 30, 2014 8:17 pm
snarky ? me ?
all in good fun
Posted: Wed Apr 30, 2014 8:36 pm
by Moderator
You now have a poll .
Posted: Wed Apr 30, 2014 9:06 pm
by larryeddington
I repeat quadruple redundancy, taper plus 2 nuts plus cotter pin. IMO does not really make any difference, But I would go with big nut, little nut as jam and cotter pin and would forget it. If one is really worried use two big nuts the second one castellated and cotter pin.
after that weld it on!
Posted: Wed Apr 30, 2014 9:09 pm
by larryeddington
Really the cotterpin is the coup de grace and cinches nothing coming off.
Posted: Wed Apr 30, 2014 10:13 pm
by The Dog House
I agree with Commissionpoint on this one. I didn't go to Clarkson, but the University of Massachusetts teaches the same thing. The large nut keeps the propeller on the shaft, the small nut keeps the large nut from loosening. Keeping the propeller on the shaft requires more strength than keeping a nut from loosening, so the large nut is used first.
Posted: Wed Apr 30, 2014 10:42 pm
You can give a good argument both ways , Even engineers don't agree here . I real life I seen props say and props loosen boat ways .
Posted: Wed Apr 30, 2014 11:30 pm
by BarryL
It all comes down to a matter of perspective...
Think of it this way.
You are the Prop and you are on a shaft. We are turning you in a direction that you have to fight against to make my 17000 lb boat go forward. You being the prop will naturally want to climb up my shaft to avoid work. To keep you from avoiding work I will put a big nut on my shaft so you cant climb my shaft. And just to make sure I will put a smaller nut on my shaft to help the big nut keep you from climbing my shaft.
There you have it folks...
Big nut closest to the prop narrower nut helping the thick nut stay in place.
Barry
Posted: Wed Apr 30, 2014 11:41 pm
by Big D
prowlersfish wrote:....After lapping in the prop , I install the prop using the big nut and tighten . I then remove it install the small nut retighten and install the large nut .
++1
Wow, somebody that does it right!
Small is left on first and large last. Tightening the large nut on the jam nut slightly distorts it jamming the threads. Having said that, walk through any marina and 90% of these are reversed in practice. I'm okay with that because I like getting paid to correct the results.
Posted: Thu May 01, 2014 8:10 am
by rmatt
Big D wrote:prowlersfish wrote:....After lapping in the prop , I install the prop using the big nut and tighten . I then remove it install the small nut retighten and install the large nut .
++1
This is the way I do it also!!
Posted: Thu May 01, 2014 1:03 pm
by Paul
In the case of a propeller, small nut first. Tightening the back nut last will remove some of the applied retaining force from the threads of the front nut. That being said, the rear nut will be carrying the bulk of the load which is why it makes sense to have the larger nut at the back.
The idea of using the large nut to seat the taper and then switch it out is a good one.
Posted: Sat May 03, 2014 10:41 pm
by larryeddington
And put the darn cotter pin in!
Posted: Sat May 03, 2014 11:39 pm
by Big D
larryeddington wrote:And put the darn cotter pin in!
First or last?
Posted: Sun May 04, 2014 7:53 am
Big D wrote:larryeddington wrote:And put the darn cotter pin in!
First or last?
pointed up or down
Posted: Sun May 04, 2014 10:01 am
by Big D
prowlersfish wrote:Big D wrote:larryeddington wrote:And put the darn cotter pin in!
First or last?
pointed up or down
Good one!
