Re: Salon Ceiling Material
Posted: Mon Mar 09, 2015 6:08 pm
http://s869.photobucket.com/user/rickdo ... %20ceiling
For Bob and P-Dogg and anyone else doing their ceiling. Hopefully, these photos may show what I ended up doing. You can see in one photo where the foil is glued into place, before the headliner panel was installed. For the most part I left an air space between the glued insulation foil and the new headliner.
The headliner was a cream vinyl leatherette that I bought in a large roll from an upholstery shop.
I bought some luan hobby board in 4 X 8 sheets and cut it to fit the salon ceiling in the pattern I wanted.
Then I spray glued 3/8" foam to the luan panels
Finally, I cut and glued the leatherette to the foam after cutting it a little larger than the luan panels, in order that I might wrap the leatherette around each panel on all four sides, stretch it tight and then staple it to the reverse side. I stapled it every quarter inch.
I fastened the upholstered panels to 3" wide, 1/4" plywood strips that I'd already framed the ceiling with.
The fiberglass of the salon roof in very thick and good to screw into. I junked all the wiring and then re-wired the ceiling lights.
Since these photos were taken, the original teak trim panels by Trojan were re-installed around the perimeter.
