Crusader 454 needs priming to get it started
Re: Crusader 454 needs priming to get it started
Holy ship!
oil&water
Post by oil&water »
Glad things didn't turn more tragic. Thank you for sharing your story. Sometimes our life lessons are hard to tell due to the resulting insult to our ego. I know mine sure are.
Currently Trojan-less :?
My Chrysler marine engine manual recommends using a pump oil can of gasoline to fill the carburetor float bowl through the vent tube before starting. Not sure I would do that...
Our last boat had a Mercruiser 454 with a Rochester Quadrajet that was always difficult to start if laid up for more than a day or two. Lots of cranking was needed, to the point that I had to wait and let the starter cool down a couple of times. Wish I had known about the fix Jamie mentioned.
gettaway
Post by gettaway »
I have 1984 454 350's and had the same cranking problem described throughout this thread, I bought a matched pair of remanufactured Quadrajet carburetors and it instantly fixed the problem, the boat starts almost instantly and both engines run smoothly with little exhaust smell. I still have the the pair I pulled off if anyone is interested in a good rebuildable set.. I'll sell them cheap !
1984 Silverton 37C
Silver Lining
Scott
