Page 20 of 41
Re: 1987 10 meter mid cabin complete restoration.
Posted: Mon Sep 16, 2013 8:55 pm
by yorklyn
Posted: Thu Sep 19, 2013 6:55 am
by BobCT
Todd,
Do you know if that sink would fill the opening on the old counter? I've been looking for a sink replacement but haven't had any luck finding one. I don't mind enlarging the opening and thought that would give me lots of options.
Posted: Thu Sep 19, 2013 9:06 am
by RWS
I'd LOVE to do a deeper sink ( and newer) on my 10 Meter Express. Problem is it's directly above the fridge, and extremely tight.
Had to tear off the top of the new fridge just to get it to fit under the drain!
The other option is to raise the countertop - LOL !
Todd - this project looks amazing !
Posted: Thu Sep 19, 2013 6:46 pm
by yorklyn
Bob,
heres the sink i used, got it through home depot online.
http://www.homedepot.com/p/t/203864416? ... jt5xsasiQI
My new counter is an exact duplicate of the old one. I'm still playing with the spacing of the drawers but i know i can make it work. I took the top "faux" drawer front and moved it to the bottom spot since it was thinner. i then lowered the sliding drawers and this gave me the space i needed for the drain.I'll post you some pics when i get a chance.
Harris, if your sink is above the fridge, this is not the sink for you. If you figure your max depth look on HD web site. i was impressed with all the choices and sizes.
Posted: Thu Sep 19, 2013 6:47 pm
by yorklyn
Oh, Thanks for the complement Harris!
Posted: Fri Sep 27, 2013 9:15 pm
by yorklyn
Finally got the new pad for the radar mount done. removed the arch today and got it and the swim platform primed.
Posted: Sat Sep 28, 2013 9:08 am
by Unchained
Hey Todd, very nice work! I'm taking my arch off this year to replace the same type of rot. Your posts have been extremely helpful to me. Many thanks. What type of primer and paint are you using? Any specific color white? I don't know the exact color Trojan used or if it's just a standard gloss white boat paint.
Let me know and keep up the good work.
Mike
Posted: Sat Sep 28, 2013 9:24 am
by yorklyn
Mike, i used awlgrip 545 primer and awlgrip cloud white but i doubt it would match gelcoat . you will have a heck of a time even getting close with paint. if you don't have alot of holes to patch you could wet sand the gelcoat and get it looking like new.
Posted: Sat Sep 28, 2013 9:46 am
by Unchained
Thanks, I'll see what I can do on wet sanding then.
Mike
Posted: Sat Sep 28, 2013 10:44 am
by yorklyn
I have found the gelcoat to be quite thick. i sanded the arch with 80grit once and 220 grit 2x using a DA sander and never went through the gelcoat . im not sure of the exact grits to use but i would feel very comfortable starting with a coarse grit and working up to a very fine grit while wet sanding to get a mirror finish .
i can't even count the number of times i sanded the entire hull while patching and fairing it. i only sanded through in one spot about 3 inches round. the thickness of the gelcoat was very impressive.
Posted: Wed Oct 02, 2013 9:27 pm
by yorklyn
Posted: Thu Oct 03, 2013 4:10 pm
by yorklyn
Posted: Sat Oct 05, 2013 10:51 am
by yorklyn
New AC is ordered. Annapolis boat show deal from Weavers marine!
Posted: Sun Oct 13, 2013 10:03 pm
by yorklyn
The new AC showed up and the Stern now looks much better!!!! Unfortunately I found out last friday that despite all of my efforts it looks like I screwed myself and will not be making my planned April launch date.
My shoulder has been bothering me since I fell while working on the boat back in September. Had a Mri on it last week and got the results on friday. Apparently I destroyed the cartilage that holds my rotator cup in place. The doctor was surprised that my shoulder has not been continually popping out of joint on a daily basis! They need to drill holes and tie the cartilage back in place. They told me It will take a minimum of 12 weeks to recover. I'm trying to put the surgery off as long as possible so I can figure out how I'm going to run my business afterwards. The Doctor said as long as I can handle the pain and its not coming out of joint I can wait until December.
So basically I need to have the boat completely finished before december if I want to launch in april! I am going to give it 110% and try to get as much done before the surgery. Worked all weekend on it and will keep it up as long as i can. Guess i'll have to see how far I can get before it starts popping out of joint.
Posted: Tue Oct 15, 2013 12:29 pm
by BobCT
Todd, major bummer
When do your engines come back? Is that the last "big" thing? It looks like you've got most of the cosmetic stuff under control. I'm sure you'll have a punch list a mile long but hopefully a lot of that stuff you can do in a the water.
