Onan 6.5KW generator Electronic Ignition conversion
gardnersf
Post by gardnersf »
My part numbers were different but I have a H series.
Wires - ON1671631 and ON1671632 (One is longer than the other)
Plugs - ON1670199
are you using the shielded plugs and metal covered wires with the $800.00 coil ? Those numbers I gave out replace those
gardnersf
Post by gardnersf »
yes, so these are acceptable replacements?
Aslo I cannot find the EIK in stock anywhere. 160-1376. Anyone know where to get one?
gardnersf
Post by gardnersf »
if I convert to the Electronic Ignition kit, do I still need the condenser?
no on the condenser
gardnersf
Post by gardnersf »
Thanks,
I ordered the cables, spark plugs and coil to go with the EIK kit I found. Hopefully the generator will run much better after the overhaul.
where did you find the kit.
gardnersf
Post by gardnersf »
I was contacted by a member of Smokstak forum. He had three in stock, (now two)
I then ordered the RCCK coil, wires, and plugs. Thansk for the numbers.
thanks again Scott, he's down to one. :wink:
Well back to square one again the thing wouldn't start today. Got the whole carb kit last week and I'll be puttin it in next week when I get the EIK for it.
ok here we go,going to do the following today. Install re-done carb, new gas pump and EIK and new coil and plugs and wires. It better run like a new one when I'm done.
it's a live ! and running well. :D
gardnersf
Post by gardnersf »
Great to hear! I'm planning on starting the work next week. May pull the carb this week and rebuild if I get the chance. I ordered the new coil, wires and plugs per your part numbers and have the EIK kit.
Anything particlualry difficult?
Does it seem to run better?
it was pretty much just bolt it in. But I installed the whole EIK base and cover that came with it. Did you get the new push rod for it you'll need it. you need any help e-mail me my BB is on all day.
gardnersf
Post by gardnersf »
I see that a base comes with the EIK. Too bad I spent money on an extra base. My have to ebay that off.
Did you have to trim any metal form the EIK other than the nub on the base?
