Boat Leveler Trim Tab - Bad Hinge - Any Leads?
Scorpyon
Post by Scorpyon »
OK so i went back outside and reconnected everything back up. i had some zippo lighter fluid and used a squirt inside the vent hole for the solenoid valve, then had my dad run the tabs while i 'ever so gently' taped on the threaded base, after only 45 seconds of switching between up and down, my trim tabs were functional. so i placed a few drops of transmission fluid into the vent holes. I will go back out in an hour and cycle them again just to be certain. I must say i am utterly amazed at the quality of this hydraulic system considering it is38 yrs old.
If you can find a manual for it, it would be greatly appreciated!
Thanks Tabman!
"If you find yourself arguing with an idiot, Be certain they aren't doing the same thing!"
1973 F25 Express Cruiser
"Hearts Escape Too"
