Page 3 of 6
Re: re-core and extending
Posted: Sun Feb 24, 2013 1:55 pm
by alexander38
Posted: Thu Mar 07, 2013 5:17 pm
by Rich Schwochow
Done some of that work myself, but the professional glass guys in my area say if you leave any original glass work in place it will most likely be epoxy and to mix materials is a no-no.
Posted: Thu Mar 07, 2013 7:19 pm
Rich I will have to disagree with you glass guys the chance of the original glass being epoxy is slim . And you can use epoxy to repair polyester ( or vinylester) with no issues . You just should not use polyester to repair anything but Polyester .
Posted: Thu Mar 07, 2013 7:51 pm
by alexander38
The Carver platform was polyester glass and all the new glass is vinylester. poly being the lowest cost and epoxy being the high end I can't see any boat Co. using it to make things with it from a factory line. Vinyl being the norm now. poly is still used alot above the water line. But it is true once you step up you can't step down. That's what I've done stepped over the factory poly and went with Vinyl. Now on my hull I'm fixing blisters found some old repairs done with epoxy THAT FAILED ! Looking in to why some glass guys don't like it because if fast hardener is used it my cook off to fast and not flex with the weaker poly. So I'm removing all of it I find...For me epoxy like 3m 5200 is over rated and over used, They both have a place just not on my boat.
Posted: Fri Mar 08, 2013 6:50 am
I suspect if the repair failed it has more to do with the how it was done more then what was used . Fast hardener is fine in many cases . Now if it extremely hot out or your using it in a large volume at once , it can set off too hot and a slow hardener is in order . One thing that can cause problems with epoxy is if you fail to clean off the blush between coats .
The key is doing it right , like you did your platform I don't think you will have any problems . As long as you remember its there backing into a slip
Posted: Fri Mar 08, 2013 7:30 pm
by Allen Sr
prowlersfish wrote:I suspect if the repair failed it has more to do with the how it was done more then what was used . Fast hardener is fine in many cases . Now if it extremely hot out or your using it in a large volume at once , it can set off too hot and a slow hardener is in order . One thing that can cause problems with epoxy is if you fail to clean off the blush between coats .
If his luck is like mine he will forget the EXTENSION and bust it up!
Just pull in and be safe!
Posted: Sat Mar 09, 2013 6:52 am
by alexander38
backing in will be fun ...but this should help
http://www.amazon.com/Rear-View-Safety- ... B002GM5GKO
Epoxy don't give like glass resin....
Posted: Sat Mar 09, 2013 7:29 am
by Allen Sr
Posted: Sat Mar 09, 2013 7:31 am
That inflatable is back there for more then one reason .
Posted: Sat Mar 09, 2013 9:45 am
by alexander38
You OLD guys are hoot! ...And yep I can record to, can't wait for the first pole dancing text...
Posted: Sat Mar 09, 2013 7:34 pm
by Allen Sr
alexander38 wrote:You OLD guys are hoot! ...And yep I can record to, can't wait for the first pole dancing text...
Well when its recorded you realize you ARE obligated to post it in pontifications section so we can judge you on your capabilities!
Posted: Sat Mar 09, 2013 8:38 pm
People in glass houses .... Just saying
Posted: Sun Mar 10, 2013 6:04 am
by alexander38
Your pushing closer to 60 than me....just saying... And I'm a judge not a dancer, I'll post here not Pont after all it's boat related
But all B.S. aside this has been the best off season yet for me. Workin' on the changing things on the Carver has been a blast.
Posted: Sun Mar 10, 2013 7:17 am
by Allen Sr
Posted: Sun Mar 10, 2013 8:25 am
by alexander38
At least I'll have proof I left the dock
