Offer just acceted on 1981 F32
Yes and No. Not all will be plumbed for 'dockside water', but you can add dockside water to any F32 with one of the many generic after-market kits.jeffsock wrote:Do all F32's have the ability to pressurize the system from the hose? All I saw in my quick inspection is a regular garden hose type spigot, maybe it is somewhere else.
If it has dockside water, the fitting will be like a normal hose style fitting in the hull, like this one or a plastic version:
If you have a full spigot (potentially port side underneath the side shelf in the cockpit?) it is probably a raw water wash down system. If hooked up, there will be a pump that pulls raw water through a fitting in the hull bottom (starboard side, outboard of the engine on my '79) and spits it out of the tap.
Not getting this one... see email from surveyor
"The cyilinders should be 125 psi each
1 & 2 were 100 / # 3 -125 psi / # 4 had water in it.
The manifold and risers on the inboard side of the starboard engine needs replacement.
The outboard was replaced according to owner
the spark plug wires are the wrong type, staright plug boots, need to be 90 degree bent type.
The wiring for the batteries needs up grading, new ends"
Who replaces one riser and manifold?
Someone who found water in the cylinders on the outboard side, fixed it, then put the boat up for sale!jeffsock wrote:Who replaces one riser and manifold?
Sorry this one didn't work out, BUT for what it's worth (good or bad), if you like the styling of the F32 there are a lot to choose from. AND... you just learned (and hopefully taught some people) the value of getting a survey, mechanical inspection, and seal trial before you buy!
- TADTOOMUCH
Water in engine
Well now is the time to tell the owner you are interested in buying as is for $9,000. Or he can waste his time trying to find someone who won't do a survey. You can get new manifolds and risers installed and if the engines are low enough hours it might be fine. That way you can still get a great boat and fix the things that are wrong. If the hull is in good shape and the engines are low hours it might be worth it. Now you know why the price was a little low.
The spark plug wires may be an issue but my plug caps are straight on my 360's
The battery cables can be replaced pretty cheaply.
Now you are in the drivers seat at least. See how bad the seller wants out of it. A bird in hand with cash is better than two in the bush without cash.
The engine if low hours is not ruined if it had some water in the cylinders. Just get it fixed and dried out and after changing oil and some use it will be fine.
Boat Name: A TAD TOO MUCH
Re: Water in engine
+1 - I agree 100 %. If the base is still in good shape, you can repair theese manifolds very easy (we have done this in last august)TADTOOMUCH wrote:Well now is the time to tell the owner you are interested in buying as is for $9,000.
Some rotten battery plugs are done in half an hour without any money.
So for me personally is there no reason not to buy this boat.
(exept you do not want to work anything at your boat - but Trojan's still needing some)
Greetings - Heiner
Thanks everyone for the comments. The surveyor said the engines are tired, low compression and high hours I think it was 2000 hours. Just seems like there are a lot of boats out there that will have the basics in tact.
A lot of you guys are much more mechanical than I am - I just want to avoid re powering a boat I buy this year.
I am also thinking of spending a little more for a newer boat that I can finance, since the interest is tax deductible as a second home, it is close to free money.
I was really hoping the engines checked out strong. I knew the boat was gonna need a lot of TLC, I was prepared for that. Thanks for all your help - hopefully I will end up with an F32 but also looking at a couple of Silvertons in the area.
Silverton - is a very stylish boat, never to compare with Trojan's.
All of the interior is more luxurious and shiny - it's just the end of
Trojans's idea of a very useful boat. But if you would ask me to choice
one of them - I prefer the timeless style of our F-32 ...
But do what your heart is telling you, Silverton's without problems ???
Greetings - Heiner
Greetings - Heiner
- 74TrojanF36
74TrojanF36 wrote:Go check out a F36! much more boat then the F32!
Yes it is more boat but in fairness to the F32 Not sure I would say much more , I know both well , The 36 has some more room inside and a larger cockpit with more free board , you may not notice the size difference inside partly due to the lay out ( well done) . The biggest negative about the F36 it will burn more fuel as it weighs 33% more 12000 vs 16000
Both are well set up boats and I had considered both . I did end up with a F36 why ? hard top and diesels where the main reasons . I would have been happy with a F32 also .
- TADTOOMUCH
manifolds
Well with 2000 hours on the engines I would run away from this boat then. Sounds like she was used a lot.
Repower may be an option for about $8,000
There are quite a few of the F-32's out there so keep looking and another one even better will show up.
Best wishes
Best wishes
