1974 F-25 Salt Water Progress
I agree with your method rb I just like using a brush more so on a small area , taping the cloth on no way .
Larger / wider area , I would likely use a roller .
Re: hull damage
+1. They are the best IMO, can't beat them. Brush the resin on first, then roll out the glass with one of these to get rid of bubbles and flatten/shape the glass mat without removing any of the resin.rbcool wrote:.... The groved (kinda like a bolt) roller is even better.
Ron
Here are some pretty good pics
http://www.diytrade.com/china/pd/290744 ... ler_1.html
After using one, I've never gone back to anything else. When done, dip it in acetone, brush off the resin in the grooves, and you're ready for next time. I've got a couple of different sizes, each size also works great at creating different sized consice radiuses at corners effortlessly.
the grooved roller is the sh## for West System, Making a engine cover for a Chesapeake work boat and the roller works great... just keep it clean with acetone..
yes yes these are all good, after my years of watching many men try many different methods. we all end up with the same results, all comes down to ratio of hardener for the "bubbles"
on this repair, i had already showed you where i pre-resined and let it dry. then blocked and applied fabric repair. guess you didnt see that. I dont get bubbles, because I wait. pinholes are an example of to much hardener. people that dont agree with waiting, thats why they list ratios on the side of the can, for people that dont know what they are doing!, kinda like making baby formula! ewwwww bad gas!!! anyway. roller, brush, mesh first, mesh last. blah etc. as long as you have a solid prep station. and wet mesh with the proper ratio mixture. Well you guys can argue all night long. You all have the same repair. now when I roll out my inner fish deck area. that will be different! this repair was a collision repair! I didnt see anyone talk about the long strand hair? why not? what about the polyester thats next? or the urathane primer to seal it? this was a collision damage and all I showed was how "I" would repair it. Hence fiber glassing 1,2,3. we are all correct here. No need to disect unless you would like to demonstrate different areas. Fiberglassing comes in many ways!! for many reasons!! I will do my front window closure differntly, as I will glass my deck in another way. Go outside and punch a hole in your hull and show me how you would fix it, please?
no not at all, just noticed the disection like a frog in high school, thats why i said we are all correct here. fiber glass can be done in so many ways for so many reasons its rediculous. I just noticed the well I would. blah.. i think we are all correct, its ok/ the junks gets hard!! real hard!! I put a rear 1/4 panel in a 76 crovette one time 5 years ago. OMG did I lesten to some &^#%. today she is just a pritty. Glass seems to be glass. i agree with mesh tickness in areas and ideas of how to. so i guess i read yours wrong, but we are all doing it right is what i was trying to say. IMO
