F32 engine trouble
Posted: Wed Aug 09, 2017 10:51 pm
1977 F32 with twin LM360 engines
Problem: on wide open throttle both engines only go up to 3000 rpm and boat max speed is 17 knots.
Emptied both 60 gallon tanks filled with new gas
Replaced both fuel filters
Blew out both gas lines
Bottom of boat is clean
When wot both carbs all barrels are open, took off flame arrestor during run to check.
Checked and lubed mechanical advances on distributors.
Ballast resistors, replace one to try no help, not sure right one cannot find a dual at .5 ohm and 5ohm.
Pickup coil tested at 284 ohm resistance according to old manual I have supposed to be 350 to 550 ohm, not sure they both would fail at same time.
Ecm tested with multi tester per manual
They start right up and run fine up to the 3000 rpm, when I wot them they stay at 3000 rpm
Any suggestions please help
Rich.
Rich.
