In past years, I've ran the engines in the yard before dropping in by connecting a garden hose to the intake hose before the external raw water pump.
This year I purchased one of those "plunger" devices that you connect a hose to from below. It didn't work out so well. I could run the engines at idle, but when I started to run the RPMs up, they started to overheat with anything over 1700.
I think the issue is the 3/8 restriction of the hose going into the plunger. Anyone have a similar experience?
Running on shore
Running on shore
Current Fleet:
2000 Carver 450 Voyager
1994 Scout 15'
2005 Caribe LCX9 dingy
1981 16' Hobicat
1994 Scout 15'
1981 16' Hobicat
Happy day! Splashed in today around 10AM. Motors ran fine, at any RPM, not heating problems. I made note of flow out the exhaust while connected to the hose vs idling at the dock. About 3X more water at the dock with an unlimited supply! I must pump pretty close to 30 gpm
Only about 3 mi from where I drop in to my slip and and everything went perfect! Its now officially summer as far as I'm concerned
Current Fleet:
1994 Scout 15'
1981 16' Hobicat
1994 Scout 15'
1981 16' Hobicat
