1981 F32 water tank problem
Posted: Sat Jul 07, 2018 12:22 pm
by fpawn
As I try to fill the fresh water tank there seems to be a blockage at the top of tank. I took hose off to first check and that was fine. After I secured on hose and put floor back, still same problem.. Is there some kink of back flow valve at top of tank?? Any ideas??
Tanks
Re: 1981 F32 water tank problem
Posted: Sat Jul 07, 2018 2:51 pm
by kallen
Check the vent at the top of the tank
Posted: Sat Jul 07, 2018 5:18 pm
by fpawn
Thanks. Going to try that in the morning. Hope I can get to it without lifting floor again!!
Posted: Sun Jul 08, 2018 4:46 pm
by ken64k
You could try putting a vacuum hose to the outside of the vent and see if you can clear it out or put a water hose to the vent. With the vacuum you won't be pushing any dirt or what ever into the tank.
Posted: Sun Jul 08, 2018 5:57 pm
by mikeandanne
The water tank vent termination on our 78 was inside the boat attached to a support just behind the removable coaming panel Stbd side......only vents in the hull were gas tanks and holding tank.I can't imagine why you don't want to lift that back deck again....
Posted: Sun Jul 08, 2018 8:24 pm
by fpawn
I am not lifting it, n
my son is!!!!
Posted: Mon Jul 09, 2018 8:41 pm
by P-Dogg
Ahhh, so the deck is voice activated!
