COIL HEATING UP AND CUTTING OUT
Posted: Wed Aug 01, 2018 9:38 am
by PLAYMATE
HAS ANYONE HAD THIS PROBLEM ?
1977 360 CHRYSLER WITH ECM. NO POINTS.
I CAN NOT FIND THE CULPRIT!!!
THANKS'.
Re: COIL HEATING UP AND CUTTING OUT
Posted: Wed Aug 01, 2018 10:55 am
by horhay1946
That version uses a ballast resistor which drops the voltage in run. Check the voltage at the positive of the coil when in run. should be about 8v. Possible culprits are the resistor or the start switch or the electronic control box. You can switch to a pertronix unit and eliminate the electronics box and the ballast resistor.
Posted: Wed Aug 01, 2018 11:55 am
by PLAYMATE
THANKS FOR THE REPLY. ITS DRIVING ME NUTS.
I WILL LOOK INTO BOTH.
Posted: Thu Aug 02, 2018 8:50 pm
by Reel Easy
I had the same problem. I switched to Pertronix dist. and its fixed. I can finally relax idleing through the busy channel and docking.
Posted: Fri Aug 03, 2018 12:03 am
by WayWeGo
Also check the ballast resistor, they can fail and have the same symptom. My money is on either the control box or the ballast resistor, both of which are common failure items on cars as well as boats.
There are a lot of control boxes out there for Chrysler engines, with prices from below $20 to well over $100. I went with a car version from Napa for my spare, along with a ballast resistor. As far as I can tell it is identical to the Sierra marine version.
Posted: Fri Aug 03, 2018 12:13 pm
by horhay1946
I have switched to a Mallory on the starboard engine and to a pertronix on the port engine. I have some spare parts left over for the Chrysler dizzy. If you want to keep the Chrysler PM me and I will let you know what I have.
Posted: Mon Aug 20, 2018 6:49 pm
by hammerhead
not sure if i have the same issue or not. every once in a while the port motor will just die running at cruising speed but it starts right back up with no issues. any thoughts
Posted: Tue Sep 11, 2018 4:38 pm
by bssmnbll
My 76 Trojan with 360's has same problem. Can you put Pertronics in the original Chrysler distributor or must you get another dist?? I have changed the coil and ballast resisters with no change. Engines run fine until I slow down to dock, them they die but will start right back up.
Posted: Thu Sep 13, 2018 1:33 am
by horhay1946
The pertronix kit can be installed in the stock distributor. You remove the reluctor wheel and the plate with the pickup then install the pertronix kit. You will need to bypass the ballast resistor and the electronic box for the distributor. You will also need a new coil. Just follow the wiring diagram and you should have no problems
Posted: Thu Sep 13, 2018 8:54 pm
by Reel Easy
I bought the complete Petronix distributor. Installation was easy. As stated above you will need to bypass the ballast and get the required coil. I ordered from Summitracing.com they had them in stock and are local for me.
Posted: Tue Sep 18, 2018 4:35 pm
by bssmnbll
Horhay1946, do you happen to have the Pertronix kit #? I called Pertronixs with the Chrysler distributor # I have on a 76' 360 and they told me they had nothing to fit it, but I would think it would be the same as a car without the vacuum advance. Anyway, I am still looking.
Posted: Tue Sep 18, 2018 8:07 pm
by Reel Easy
Just FYI. if the bushings are worn out in the distributor from being 42 years old the kit won't fix that. I would check the play and runout on the shaft before you buy just the kit.
Posted: Thu Sep 20, 2018 5:25 pm
by horhay1946
I have another distributor that came out of one of my engines. It still has the Chrysler setup and I do not think that the shaft is worn. What you want to do is look on the tag on your distributor and that will determine which kit you need. I have Chrysler 360s. PM me for more info.
Posted: Sun Sep 23, 2018 7:59 am
by bssmnbll
Horhay1946, the only #s on my distributors are the Chrysler#36759 and #1354. the latter is a " coast guard" marine # according to a person I talked to at Pertronix. The same person said they could not id either of those #s so they could not supply a kit for me. That is why I wondered if you had the kit #. I may end up buying a complete distributor if all else fails. Yesterday, I installed a new ecm but weather in the Chesapeake has not allowed a run, so I can't tell you if I have made any gain. Bill
Posted: Mon Sep 24, 2018 10:45 am
by horhay1946
My distributor is a Prestolite IBM-7016, 7017 which uses kit # 91582. You can search the pertronix catalog and on page 24 is the listing for all Chrysler marine distributors. You may have to go the new distributor route or find a later module Chrysler distributor. My boat is an 81
