Throttle cable between helms
tonydelgreco
Post by tonydelgreco »
When I throttle down to idle from the bridge the lower helm does not bottom out with the upper helm. Cable at carb. is adjusted. Any adjustment between helms?
Tony
Re: Throttle cable between helms
Yes , the cable can be adjusted on both ends
tonydelgreco
Where would I find the adjustment points?
At the end of the cable at the control
