1977 Trojan 318 engine performance
1977 Trojan 318 engine performance issues?!
I have twin 318's, electronic ignition, one helm
my best performance is 3100 RPM and 29 MPH
my props are factory size, and specs...
I seem to read a lot of people getting 4000 RPM, and higher speeds...
so all you engine performance people on here!! what is causing both my engines to perform like this...
they run great, always start, idle at 500 for 4.5 mph... consume normal amount of gas... etc...
all ideas and thoughts welcome was well as top three performance upgrades and benefits ...
thanks!!!
Svend
thanks!!!
Svend
Raymarine EV 100 Auto Pilot
Re: 1977 Trojan 318 engine performance
What size props do you have ? 29 MPH is good 3100 rpm is low . Also 4.5 mph seems high for 500 rpm . I don't remeber my F30 being that fast at idle speed . Are you sure your tachs are right ?
prowlersfish wrote: ↑Sun Jul 21, 2019 11:48 am
What size props do you have ? 3 or 4 blade ? 29 MPH is good 3100 rpm is low . Also 4.5 mph seems high for 500 rpm . I don't remeber my F30 being that fast at idle speed . Are you sure your tachs are right ?
Thanks for reply!
the prop has this stamped on it: 14 R 11
and they are 3 blade props
look forward to your thoughts!
Svend
Svend
While that is factory size most will do better with a little less pitch . Our boats start getting a little fatter from day one.
Frist make sure the tachs are right .
- Paul - SW Ontario
100% Correct...prowlersfish wrote: ↑Mon Jul 22, 2019 9:06 pm While that is factory size most will do better with a little less pitch . Our boats start getting a little fatter from day one.
As mine 'fattened up' over my first ten years of ownership, which gradually dropped my performance to 2800 rpm (3000 on a good day)...I went with this suggestion and re-pitched.
Went from the factory 14 R 10...down to 14 R 9
Result, right back to 4000 WOT under load...recovered gusto when powering thru confused water here in Lak Erie.
Not wanting to put the old girl on a diet (the Trojan that is
1973 Trojan F25.5 - SW, ON.
2012 Triple Axle trailer
1978 C&C Mega 30' Sailboat
2014 Triple Axle trailer
2016 Highfield CL290 BL RIB
2017 20hp Suzuki 4 stroke
great ideas!!
3 blades or 4 ?
what is a good way to test tach's to make sure they are accurate...
thanks!
Svend
3 blades or 4 ?
thanks!
Svend
Photo tach to check your tachs . drop a inch and see how it goes ( 2" if going 4 blade ) .
- Paul - SW Ontario
Mine are three blade NiBrAl props.
hi prowlerfish
can you explain Photo tach to check your tachs
I am a newbie on engines
also, would love to hear your thoughts on 3 glad vs 4 blades...
and your thoughts on goals for a cruiser boat with most time spent at low speed cruising, and then wanting to get home quickly sometimes (but never needing a quick start off line for say water skiers)
thanks!
thanks!
