Page 1 of 2
36 tri-cabin fuel tanks
Posted: Sun Feb 23, 2020 6:44 pm
by Rhino
Rhino here, I'm new to the forum and its a pleasure to meet all of you! My wife and I are the proud owners of a 1974 36 Tri Cabin. But I have a question about the fuel and water tanks. Which one is the water tank ? If I could get in the bilge, I may be able to figure it out. If someone could help me out I would be much appreciative.
Re: 36 tri-cabin fuel tanks
Posted: Mon Feb 24, 2020 6:22 am
Are you trying to ID the fill or the tanks ? (fillers are normally labeled ) Hopefully some one with the rear engine tri will chime in . later mid engine tri's would be different . You can also get a owners manual from Beacon marine .
tri cabin
Posted: Mon Feb 24, 2020 6:01 pm
by waw1949
I remember the aft cabin as having the gas tank under the bed. starboard side had 4 large mirror doors. inside was a cedar lined hanging closet some draws and shelving. at the foot of the bed was an entertainment system...tv radio. port side had a upper cabinet with strip lights a counter top and a swivel stool. there was a bath with shower and toilet and tile floor. the salon had a cabinet with pop up tv. forward was a washer and dryer and full size fridge. the fly bridge had an ice maker sink and "bar". haven't seen any pix that match.
Re: tri cabin
Posted: Mon Feb 24, 2020 10:17 pm
waw1949 wrote: ↑Mon Feb 24, 2020 6:01 pm
Was it a Tri-cabin ? What year ? Rhino's Tri cabin would have the engines under the rear bunks (beds)
Posted: Tue Feb 25, 2020 9:57 pm
by Rhino
Yes, engines under twin beds, and tanks under salon floor. I need to access everything from a very small space or cut out the floor. I would rather not cut.
Posted: Wed Feb 26, 2020 6:55 am
by rickalan35
Hi Rhino,
I owned a 1974 Tricabin for 16 years before buying my current Trojan.
As you already know, the two gas tanks are located directly under the salon floor. The fresh water tank is almost invisible when you hop down into the bilge, especially if you have a genny located there as well. But having said that, the water tank itself is located against the outside wall of the bilge on the starboard side on the "other side" of that starboard gas tank.
It's amazing what you can do with tricabins. I stopped using my stock water tank but left it there. Too difficult to remove. I installed a new 20 gallon plastic water tank in that space directly in front of the starboard-side gas tank. It's big enough. Then I installed an air conditioner in the storage space locker directly across from the door to the head. It's plenty big enough for a 10,000 btu unit.
I also installed a vacuflush system and placed the 20 gallon plastic holding tank in front of the port gas tank, almost against the partition for the head. Not as big a holding tank as I would have liked but served it's purpose and allowed me to get rid of the stock toilets.
Hope this helps
Rick
Posted: Wed Feb 26, 2020 7:05 am
by rickalan35
By the way, Rhino - In regard to the steps leading up from the rear bedroom to the salon, you can pull down the top step (it's riser is hinged) in order to get access to the starboard side gas tank level sensor. (You'll also notice the fresh water tank, I believe) On the port side, you can look under the galley sink on the floor of the cupboard. There you'll find a trap door of sorts where you can access the gas tank level sensor for the port tank. Just sayin'.....
Posted: Wed Feb 26, 2020 10:57 am
by WayWeGo
Rhino, you may have already learned this, but Beacon Marine can supply the original documentation package for your boat that has lots of great info on how it left the factory, including the wiring diagrams. It is well worth the money.
viewtopic.php?f=1&t=2695
Posted: Thu Feb 27, 2020 2:51 pm
by Rhino
Ok, when I raise the generator cover, which is the salon floor, and look to starboard and port I have two galvanized barrel type tanks on both sides. Approximately forty to fifty gallon each. Four tanks total. There is no space forward of either of the two forward tanks. I will look for the hinged step and access panel under the galley sink tomorrow. Another thing that seems really weird to me is that the previous owner has put a small ten gallon shop type air compressor in the bilge forward of the generator. A red rubber air hose has been run from it to the control panel at the helm. What in the world is it about? The only explanation I can come up with is that another hose was connected to it, and was used to blow the boat off or to inflate large inflatables. Any other ideas? You guys are a huge help to me! Otherwise I wouldn't have a clue about what I'm doing! Thanks! And keep the info rolling in.
Posted: Fri Feb 28, 2020 12:43 pm
by WayWeGo
The compressor and hose was probably for an air horn.
Posted: Fri Feb 28, 2020 8:17 pm
WayWeGo wrote: ↑Fri Feb 28, 2020 12:43 pm
This ^^
Posted: Sat Feb 29, 2020 12:58 pm
by BeaconMarineBob
As stated in the other posts the fresh water tank is on starboard side directly under the AC / DC panel and is a fiberglass tank which is fiberglassed to the Hull. It has a plywood top. The whole salon floor can be removed.
The owners manual for your Tri Cabin comes with the electrical drawing, the original invoice and around 100 pages of information on each system of the boat.
Here is the link to the Owners Manual
We would need your Hull number to make one for you.
Your Hull number is on a aluminum plate by the AC / DC panel
https://www.trojanboats.net/zencart/ind ... cts_id=615
Posted: Sun Mar 01, 2020 9:32 pm
by rickalan35
Dear Rhino,
Don't know what the second tank on the port side is for. I didn't have a second tank of the left side in my 1974 Tricabin. So just like you, that tank's a mystery to me.
Next time your on your new boat, please remove the salon floor hatch to the bilge that you mentioned in your previous post (I used to stand it up and then lean it against the stove) . Doing this will give the bilge area below some light. Next, unhook the removable steps leading from the head up to the salon. As you know, these three steps have little hooks and eyes holding them secure.
Undo the two hooks and pull the steps straight back toward the v-berths first, before lifting them up. You can lay them on one of the berths. By the way, in order to remove these three steps, first open up the locker door (the locker that is under the L-shaped settee) . If you don't then the steps will hit the moulding around that settee locker door.
With the steps removed, you will notice and be able to open a different access hatch, also leading to where the generator is currently located. Then if you close the settee locker door and open the door to the V-bunks and leave it open, you can lay down comfortably flat on your stomach and stick your head through the access hatch and look around especially with a flashlight. It will give you a pretty good view from a different angle. I had the air conditioning intake water pump installed at this point and I would clean it's weed filter, while laying in this position. But I figure that this angle will get you a pretty good look at those tanks, especially to see how the mystery tanked is plumbed. From this position, you can manually start your generator as well as charge the generator battery with a car charger (just sayin')
What kind of toilets are in your boat. Is it possible that you have vacuflush or similar units and a black water holding tank was installed at some point?
I rather doubt this is the case because, although Bob is totally correct and the salon floor is removable - you want to
avoid it if possible because it is a big job, Rhino. I know from unhappy personal experience. A big big job.
Anyway, I've talked a lot here. Long winded.
Keep in touch with the Forum Rhino, and welcome!! by the way.
Rick
Posted: Wed Mar 04, 2020 11:33 am
by Rhino
Thank you Rick! I did what you said and the best I could see is that the tank must be extended range fuel tanks. What plumbing I could see, is all fuel related. I am going to post the numbers on my boat if anyone can come up with something. I have the Thetford pump out type of toilet,kinda looks like a porta-pot , which I'm going to change ASAP. Thanks again for all your help! Rhino
Posted: Thu Mar 05, 2020 3:06 am
I Believe the owners manual will have all that info , check with Beacon . Photos of the tanks ?
