raw water impeller
raw water impeller
changing the raw water impeller on 671 ti, any tricks someone can share?
Re: raw water impeller
Dish soap helps . Some use plastic ties to compress the impeller . Also Do not worry what direction the blades are compressed . as soon as you turn the engine over they will be in the right direction .
