Ignition part
Posted: Wed Jun 05, 2024 9:03 am
by JPP
I am looking for an ignition module (ECU) wire harness for a 1976 318 CI Chrysler engine with electronic ignition. Can anyone help or direct me to a possible source. I will consider a used harness as well. THX JPP
Re: Ignition part
Posted: Wed Jun 05, 2024 3:13 pm
by larryeddington
will look I think I have one, I put new distributor in and did away with it. It is the same one used in chrysler products of same year. Ii has a five pin plug that is held tight with central screw. In any case will check.
Re: Ignition part
Posted: Wed Jun 05, 2024 11:33 pm
by jimcarriere
That style wiring harness was used on virtually all Chrysler 6 and 8 cylinder engines in the 1970s. You could probably find a nice one in the nearest junkyard pick-n-pull (self serve or the kind where you ask the people in the office to get it for you, either/or). There were detail differences in ECUs and distributors, but the harness itself is nothing special and millions of them are out there.
Where are you located?
Re: Ignition part
Posted: Sun Jul 14, 2024 10:44 am
by larryeddington
I have two of them and you can have them, both have the pigtailed plug. Will send them to you. Provide address.
