Edelbrock Carb Choke Wiring
Posted: Tue Jul 16, 2024 7:38 am
by Martino
Has anyone updated to the Edelbrock Marine Carbs? If so what was your solution for the hot wire? The Edelbrock info says don't use the coil or alternator.
The engines are Chrysler 360's
Re: Edelbrock Carb Choke Wiring
Posted: Tue Jul 16, 2024 10:28 am
A lot of people have hooked it up to the + on the coil or the alt. If It was mine I would find a 12-volt ignition feed. You did not say what engine you had.
Posted: Tue Jul 16, 2024 5:45 pm
by Martino
I'd rather not go to the positive coil side or the alternator. Trying to figure out an ignition feed connection.
The engines are Chrysler 360's.
Posted: Wed Jul 17, 2024 8:23 am
12-volt power on the ballast resistor.
Posted: Wed Jul 17, 2024 9:00 am
by Martino
prowlersfish wrote: ↑Wed Jul 17, 2024 8:23 am
Thats a great idea ! I didnt think of that. Ill give it a try. Thanks
Posted: Wed Jul 17, 2024 1:14 pm
by Martino
Im thinking of creating a fused relay swith to power the choke from the starter solenoid.
Posted: Wed Jul 17, 2024 5:53 pm
It does not show the solenoid wiring, But I believe the terminal you're using to activate the relay goes to the + side of the coil. Full 12 volts cranking, lower voltage running as it feeds from the coil after the ballast resistor. Will the lower voltage keep the relay on? Would the relay draw much less than the choke coil heater? I don't know but I bet it's close.
Posted: Tue Oct 15, 2024 10:54 am
by Marko
I converted my 1982 F26 318 to Edelbrock 1409 w/electrick choke. Hooked up to positive ballast resistor (top right side of ballast viewed from aft). This is a consistent 12V while key is on.
-Marko
Posted: Tue Oct 29, 2024 1:33 pm
by Martino
So I built two harnessees based on the photos I attached for the chokes and they worked great !
Posted: Thu Oct 31, 2024 11:04 am
Thank you for the update.
