F-32 with Yanmar Turbodiesels - Performer?
Posted: Sun Oct 26, 2008 8:08 am
by RWS
I'm not a F series owner, but have learned a great deal about them here and elsewhere.
This vessel with the 315 HP Yanmars should be quite the performer, and economical as well.
Although there aren't nearly enough photos, this vessel seems to me to be a really good value.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... OTORS:1123
Great deal @ $50k
Posted: Sun Oct 26, 2008 9:17 am
by rossjo
This is a great deal @ $50k. Wish I was in the market, but I already have 4 boats (one is a diesel F32.).
The 2x315HP is great, but might even be a bit overpowered. It should run great in calm seas, but could be a handful for a novice in medium to heavy seas. With the right props, top speed should be 35 knots!
Bottom line - best F32 value on the market today ...
Posted: Mon Oct 27, 2008 12:30 pm
by rossjo
Posted: Mon Oct 27, 2008 1:39 pm
by jav
Is that 26.2 kts cruise speed or WOT?
Boot Stripe Missing
Posted: Mon Oct 27, 2008 2:02 pm
by TADTOOMUCH
I've seen this on other F-32's but why is part of the boot stripe missing on the side of boat? Did fuel vents overflow disolve them?
Posted: Mon Oct 27, 2008 2:20 pm
by rossjo
Funny - I wondered the same thing on the stripes ...
As far as speed, the quote is what he said - I think that was top speed - sounds slow ... sounds like he could easily turn more pitch ...
Posted: Tue Oct 28, 2008 10:03 am
by jav
if that is top speed - it is real slow. Mine tops out at around 24 knots but I'm only running twin 200's or 400 hp total. I'd expect a 26 knot cruise with 630 hp.
Posted: Tue Oct 28, 2008 11:07 am
by jddens
Might be comparing apples to oranges but my F30 with 660HP (330X2) tops out at about 28kts.....WOT......................John
Posted: Tue Oct 28, 2008 11:47 am
by RWS
O.K. here's a mango.....
1983 Trojan International Express Cruiser 10 Meter
33' published weight dry 12,000 actual approx weight fully loaded by hydraulic travelift 18,000.
Twin Yanmar 315hp 6 cyl turbodiesels
4 blade - 20x20 props
27.1 knots WOT with full water and fuel
Engines do make required RPM at 4100 and 4050 respectively
Posted: Tue Oct 28, 2008 12:05 pm
Maybe that F32 is a slow for 315hp becuse it has 250hp max hp (x2) ?
http://www.oya.com/others/yanmar.html
Posted: Tue Oct 28, 2008 1:39 pm
by jav
Paul -
BINGO! you are correct- His ebay listing says the engines are the 6LP-DTE which are the 250 hp versions not the 315HP (6LPA-STP/STZ) versions.
I don't know where the 315 HP figure came from...I just thought the speed was WAY off on that boat with that kind of power. It still seems a little off seeing I get 24 knots out of 400 hp... I would think an extra 100 hp would get a little better than 2 knots but that could be explained by prop/gearing.
RWS- Your international has a very different bottom than the F-32. For your hull form, at that weight and RPM, your engines are in a real happy zone. Their certainly not being overworked. You could probably get a little more (safely) with different props but why bother unless your unhappy? Your setup is just about text book perfect.... it should serve you well for years.
250 v 315
Posted: Wed Oct 29, 2008 5:35 am
by rossjo
Good catch on the 250HP ...
250HP is plenty.
I max at 28 knots with 2x225HP Cummins 6BTA5.9's, 1:1 and 17x20 props.
Still a very nice boat (not the cleanest bilge, but nice).
