f32 wiring problems?
Posted: Tue Mar 17, 2009 10:06 pm
by Tuck
hiyas!
slowly getting my trojan the way i want it, but i've now come to the point where i have to get this wiring mess fixed (hopefully...with some help, because i'm a moron)
i'm not getting any power into the starboard side, so i have to use the crossover switch to get power to both sides at the dock. i know it's not the cords. i also thought the port nav light was out, but tonight before heading home, just for funsies, i turned the nav lights on, and it came on. a minute later, i turned them on again, and it didn't. long story short, i think i have just that...a short.
my point/question is this: are these boats known for wiring problems, or do i happen to just have special problems? also, if it's something where new wire has to be run on either of these, is it going to be a pain in the azz to access and run, or is it pretty simple?
tks in advance for the input.
wiring
Posted: Tue Mar 17, 2009 10:11 pm
by g36
hey i just sent you a message. i think i can help
Posted: Tue Mar 17, 2009 10:14 pm
by Reely Hall'n
I had a lot of problems with my F30 and all the wiring. Best sugestion is get your hands on the original wiring diagrams. Between a diagram and a good tester I was able to retrace and re-wire all my problems away.
Posted: Wed Mar 18, 2009 6:45 am
by Tuck
Reely Hall'n wrote:I had a lot of problems with my F30 and all the wiring. Best sugestion is get your hands on the original wiring diagrams. Between a diagram and a good tester I was able to retrace and re-wire all my problems away.
Anyone happen to have a wiring diagram for a 77 f32 they can spare? 8)
Posted: Wed Mar 18, 2009 7:37 am
by Reely Hall'n
You can purchase a copy of an original service manual from Marine Tech. They cary many original Trojan parts along with service manuals. There number is 717-684-4145. If you give them your serial number you can also order the original build sheet for your '77. They are located in Lancaster PA.
Posted: Wed Mar 18, 2009 9:00 am
by Stripermann2
Tuck, I would start looking at corroded/ loose connections.
If you have a fax number, I'll be happy to fax you the wiring diagram I have. It was larger sheet than fax paper but I can send over multiple sheets you can decipher. Let me know.
Posted: Wed Mar 18, 2009 9:32 am
by mtwolf
I had a problem with the push pull switches on the dash , both flying bridge and helm. Replaced the switches and my problems went away with the old ones.
John
F-31
Galloway Creek Marina, MD
Re: f32 wiring problems?
Posted: Wed Mar 18, 2009 10:45 am
by gjrylands
Tuck wrote:hiyas
The AC starboard might be a defective main breaker or selector switch. (Selector switch is used only if you have a generator or if you ever had one.) Remove the cover of the AC panel. Check if there is power at the starboard main input. (Black wire) If you have power coming in, but not out, the main breaker is bad. If there is no power at the main input, then check the wiring on the back side of the shore power inlet or at the selector switch. Check for corrosion. There is little chance that the wires running between the shore power inlet and the panel are bad. The problem is usually at the end connections.
Running light. I don’t think you have a short or it would blow the breaker and none of the nav lights would work. The problem is probably in the socket. There could either be corrosion on the contacts or the contacts in the socket are bad. You can buy new contacts at most any auto supply store. You need a two pin insert and it costs about $5.00.
Posted: Wed Mar 18, 2009 12:57 pm
by 00GTP
Anyone out there have some wiring diagrams for a 79 F30 express w/flybridge? I have seen diagrams for other sizes, but not for the 30.
TIA
Posted: Wed Mar 18, 2009 4:01 pm
by rossjo
Thanks Striperman!
I couldn't remember the links ...
