chrysler 318 oil leak?
Posted: Fri Mar 27, 2009 4:30 am
by Rob Lomer
1970 sea raider 25,chrysler 318,leaks at oil filter when running..filter seems to be mounted on some kind of extention? any ideas?
Re: chrysler 318 oil leak?
Posted: Fri Mar 27, 2009 6:09 am
by ready123
Rob Lomer wrote:1970 sea raider 25,chrysler 318,leaks at oil filter when running..filter seems to be mounted on some kind of extention? any ideas?
Not fully clear on what you mean here, but will take a stab at it.....When you say extension do you mean the stub pipe that goes into the middle of the filter? Have you checked to make sure that it is not too long to prevent snugging up the filter? Can that stub pipe be screwed in further? There is a large nut around the threads that filter goes on has that been screwed up too? What size filter are you using, Fram CPH8A?
Posted: Fri Mar 27, 2009 8:46 am
by Dan Faith
Take off the oil filter and make sure the last time the filter was changed the old rubber gasket was removed. This is a common occurance when changing oil and filter the old gasket will remain on the engine and you add another on the filter.
Posted: Fri Mar 27, 2009 8:51 am
by Rob Lomer
yes it does have that tube..when running it gets loose counter clockwise and leaks..if i swing it back up to high noon,the leak slows but does not completely stop..
by Stripermann2
Here is a breakdown of your assembly. Or it should be similar. Check to be sure all o'rings, filter gasket etc, are secure. Usually, a double gasketed oil filter will gush out oil. Just be sure all is clean and tight. Good luck.
Posted: Fri Mar 27, 2009 9:14 am
by Rob Lomer
that looks like it! now i see where i am going with it ..thanks!!
318 oil leak
Posted: Fri Mar 27, 2009 9:35 am
by fpawn1
Had a similar problem last yr---had to replace the O rings on the oil filter extension--you can get the parts at Hurrikain Marine on line--works fine now
