ETHANOL Problems
rossjo
ETHANOL Problems
Post by rossjo »
Anyone having problems with Ethanol?
Our Trojan F32 has diesels, but my 25' Chaparral Express runs a 454 with Quadrajet. After sitting for 4 months, we ran it Saturdey on the hill, and it seemed OK, so we splashed it Sunday to go King fishing. It quit running (just bogged) after about 6 miles @ 1,800 RPM.
The Quadrajet carb was spewing fuel into (and all over the top of) the engine, so we opened the engine hatch and let it air out. I pulled the Qjet apart and made sure the float wasn't sticking, the float needle was working properly, the metering rods weren't hung and the accel pump was pumping. Put it back together and fuel still flowed out the top (mostly around the accel pump shaft).
We could keep it running at 1,500-2,000 RPM, which was unsafe, so called TowBoatUS ($100/year). Looks like the ethanol has eaten my accel pump seals - and possibly the rest of the seals.
Anyone else having problems with Ethanol?
I'm looking into rebuild kits, and see the Ethanol friendly kits use Viton (Dupont) seals. Anyone else have experience here?
deleted so not to offend
rossjo
Post by rossjo »
prowlersfish wrote:Yep I weedwacker down the pick in the tank eatten away lawn mower leaking fuel every where .arrrrrrrrrggggg?
I think that was a sentence?
Post by Paul »
Hi Ross,
If you have fuel that high up in the fuel bowl, where it's seeping out around the accelerator pump shaft, the plunger on the float is not doing it's job. Is this plunger rubber or steel tipped? If rubber, it may simply be time for a re-build. If steel, the fuel pressure entering the carb may be too high. Do you have an electric pump? If so, does it have a regulator?
Dirt can also keep this plunger from seating correctly.
Hope this helps
rossjo
Post by rossjo »
The float plunger is metal, and the fuel pump is the stock, Mercruiser belt-driven fuel pump with no pressure regulator that has worked for 2-3 years.
Is the seat rubber, or was there possibly a rubber piece on the plunger that has dissolved off?
Perhaps, as you say, dirt OR the mix of ethanol and non-ethanol fuels has created a gum which has now lodged in the float plunger seat? It ran OK on Sat (old fuel), but went bad after several miles (15 minuets?) on Sunday. The seat and plunger both looked visually clean when inspected when I tore the carb apart at anchor in the harbor Sunday.
For reference, I replaced the fuel/water separator (little/no water in it) on Sat, and left my 100 gallon tank filled all winter to reduce condensation.
kevin babineau
Post by kevin babineau »
i had several boats last year do this..rebuilt the carb..but one was bc the fuel pump put out 17lbs i pulled my hair out trying to figure that one out
rossjo
Post by rossjo »
Standard carb rebuild kit?
or did you find one with the Viton seals?
rossjo
Post by rossjo »
eye understand!
guglielmo6160
Post by guglielmo6160 »
I dont know what the heck you guys are talking about,, its like you guys are speaking like the riddler on batman,,, riddle me this...... lol
1983 10 meter express
farfrompuken
Post by farfrompuken »
Imagei use this and it works great
Twin 270 Crusaders
George and Joanne Holzmacher
rossjo
Post by rossjo »
Riddler?
Batman?
E-Zore?
I'm confused too ... just looking for anyone that has had issues with Ethanol "eating" their carb seals.
farfrompuken
yes had problems with ethanol. i rebuilt both carbs. guy that i use for rebiulding said( for quadrajets) he has a newer gaskets and seals that is ethanol friendly.THEN I USED THE EZZORB
Twin 270 Crusaders
jwrape
Post by jwrape »
Yea, Ethonal is harder on rubber parts than gasoline.
79' Carver 28' Mariner
ready123
Shell Marinas no Ethanol
Post by ready123 »
Are things different in the US? All Shell marinas in Ontario supply zero Ethanol Gold fuel at the dock because of the negatives of it. You should see what it does to two stroke engines as it attacks the oil in the mix!
