AC water pump relay?
Posted: Wed Sep 16, 2009 9:37 pm
by tgcasey
I have a 12M convertible and I had the compressor under the cockpit replaced. All went well except that the water pump won't come on. I have two AC units and only one pump so the AC guy said I must have a AC pump relay and that it may be bad as we check and when you turn the controls on for the AC power is at the lead that is labeled pump.
Anyone know when this relay would be on my boat?
Tom
Posted: Wed Sep 16, 2009 9:51 pm
Should be near the a/c unit it will be in a box ( about 4x4x6). just follow the wires from your a/c unit(s) there is a relay for each unit in the box
2 A/Cs = 2 relays. if you have cruse air the box is blue or white ,
Posted: Wed Sep 16, 2009 9:55 pm
by tgcasey
It does not appear to be near the AC unit either one....
Posted: Wed Sep 16, 2009 10:06 pm
You may have to trace the wiring from the pump . I am not sure were trojan put them on all the meter boats ( the one a/c I have looked at on a meter boat it was near the a/c units)and things do get moved around over the years
