Thinking about winterizing
Boaterguy
Post by Boaterguy »
Turning the calendar page... again.
I am going to winterize the boat myself. I have the original manuals, and a service manual for the Chrysler 318 but they don't clearly specify the location of the drain plugs. I have a 1975 F25
Can you tell me where the various drains are located. I want to be sure not to miss any.
(I did a search for this topic and didn't find any previous posts... unless I missed something.)
1975 F25
318 RH
Sea La Vie
gjrylands
Post by gjrylands »
There are 2 drain plugs in each engine, 2 in the exhaust manifolds, and 2 in the risers of the exhaust system. On the engine there is a drain plug about midway on the block and towards the bottom on either side. There is a drain plug in the bottom of each exhaust manifold towards the back. There is a drain plug in the bottom of each riser. All these plugs are either 3/8 brass plugs or petcocks.
You will also need the drain the strainers, transmission oil coolers, and the water pumps.
Gerry
1979 F36 Twin Chryler 440's
