Page 1 of 2
Rudder play on F-32 1978
Posted: Tue Oct 20, 2009 4:31 pm
by TADTOOMUCH
When I hauled out for the winter I noticed that my starboard rudder has about 3/16" of play in it and the port one is nice and has no play. They both rotate fine and the starboard one leaks a little more than the port did. Is this just a packing issue or do I have a bigger problem that needs more work? Has anyone removed their rudder and replaced the bushing. Not sure how the whole rudder bushing assembly is made. Can anyone give me a description of the assembly and what might need replacement/
Posted: Tue Oct 20, 2009 7:34 pm
by MTP
I have nothing to offer but a bump
Posted: Tue Oct 20, 2009 9:03 pm
Is it side to side play or up and down ?
Rudder Play
Posted: Wed Oct 21, 2009 8:40 am
by TADTOOMUCH
The play is side to side. Up and down there is no play at all.
I'm sure the side to side play is probably a bad thing and will be harder and more expensive to fix than the up and down would be if things go for me the way they usually do.
Posted: Wed Oct 21, 2009 9:05 am
by rossjo
Heres the drawing for the F36 rudder ... my F32 rudder is the same as far as I know.
Great!
Posted: Wed Oct 21, 2009 9:47 am
by TADTOOMUCH
Rossjo,
That is exactly what I needed to see. My guess is that the key on the shaft has worn or the top bearing has worn out. I doubt the packing being bad or the nut being too loose would allow that much play. Now that I have a good diagram, I can take it apart and find the culprit.
Posted: Wed Oct 21, 2009 12:04 pm
If it is side to side at the rudder you rudder port is worn and may be the rudder shaft I would replace the uper Bearing at that time
Posted: Wed Oct 21, 2009 1:38 pm
by rossjo
Glad it helped ... I'll leave it on our site
by rossjo
Posted: Wed Oct 21, 2009 7:57 pm
by LSP
Thanks Capt Ross .... nice to have
Posted: Mon Oct 26, 2009 4:56 pm
by rossjo
Inquiring minds (with loose rudders) want to know ...
What was the prognosis on your rudders?
Posted: Sat Nov 21, 2009 8:04 am
by rossjo
Tad2 ....
What was the outcome on your rudder? I have some play in mine, and would like to know how yours came out before I tackle repacking/repairs.
Thanks you in advance, Ross
Rudder play
Posted: Sat Nov 21, 2009 9:42 am
by TADTOOMUCH
Got lots of stuff to work on so the rudder will be spring project
Rudder Play
Posted: Tue Apr 20, 2010 10:18 am
by TADTOOMUCH
I found out my rudder is not loose in the packing or shaft bearing. It is loose where the rudder attaches to the shaft. Both rudders have about 1/16 to 3/16" of play in them where they attach to the shaft. Is this normal or from wear? How are the rudders held on to the shaft?
Posted: Tue Apr 20, 2010 2:59 pm
by rossjo
See the "Tiller Arm" in the drawing above ...
Look and see if its the tiller arm loose on the shaft OR the steering rod loose.
