The "Devil" and me
Posted: Thu May 18, 2006 6:59 am
I have to get into the bow and put some sealant in the "devil" at the bottom of the boat above the keel. This will require removing two bulkheads and squeezing in under the deck, so I want to do it right the first time.
My idea is to use a heavy dose of 3M adhesive caulk after thoroughly preparing the surface. Any suggestions on another method? Previously, someone poured resin in to it, but this tends to loosen and flake off, what with all the oily bilge that gets down there.
I also have a bit of a "hogback" condition in that area, as over the years of trailering, the roller that rests on the keel has pushed up the hull a couple of inches. This means that water that getsin front of the pushed-up "hogback" can get trapped for long periods, necessitating extra care in keeping the area well protected.
It's all marine plywood up there and very durable, but I worry about rot anyway.
(By the way, as you may know, the "devil" is the bottom of the boat above the keel. Makes sense, 'cause this is where all the devilish grime and jetsam from the boat winds up. And I understand that it's also the origin of the saying "between the devil and the deep blue sea." Interesting, eh?):twisted:
Any help is appreciated.
