RAILING
larglo
RAILING
Post by larglo »
I was wondering if the SS tubing that's used in the railing, be bent, using a regular pipe bending tool used by plumbers, and not damage the tubing?
I am still thinking about making an anchor pulpit, and would like to have the railing go around the pulpit as I see in pic's on other boats?
Thanks, Larry
Larry - 1980 F25 HT
"Lady G"
Mt. Juliet, TN
Danny Bailey
Post by Danny Bailey »
Small bends can be made in S/S rail tubing but to go around an anchor pulpit you may have to use angled fittings
chauzer
Post by chauzer »
or use aluminum tubing.
life is tough! it's even tougher if your stupid.
~john wayne~
Rodman
Post by Rodman »
Here is a photo of my rail if you need it.
I saw a photo of Pauls on his photo bucket here it is. These two should help you.
Trojan
koviak
Post by koviak »
Make friends with an electrician and have him make bends with a Chicago bender (electric). Slow and steady pressure will do it nice and smooth.
chauzer
Post by chauzer »
i thought a chicago bender was a bad night in chicago!
~john wayne~
rossjo
Post by rossjo »
Larry,
A pipe bender will NOT bend tubing without kinking it. We make stainless steel, folding T-Tops, (http://www.RNR-Marine.com or http://www.T-Topless.com), and you'll need to use a draw type bender.
We have 5 benders from manual to CNC hydraulic. If you come up with a good dimensioned sketch, I'll bend it for you (I can provide the tubing as well if you need it).
Danny Bailey
Now that's a good deal!!
reelfishin
Post by reelfishin »
Definately would go with Rossjo. I think you would get a better job and the opposite bends would match. Believe me I can bend pipe but getting to bends exact is not easy. Also that 180 degree bend for a amateur would be very difficult. You will spend more money trying to do it yourself than having it done right the first time.
Larry, take Ross up on the offer I ran a pipefitter/shipfitter shop in the Navy what you're wanting to do is left to the Pro's with the tools and skills to work with S/S
larglo
Post by larglo »
Capt, Ross,
I copied your post and put it into my Organizer. And I hope sometime this summer, will take you up on your offer.
Thank you very much!
Larry
Larry - 1980 F25 HT
"Lady G"
Mt. Juliet, TN
rossjo
Post by rossjo »
Sure ... come on down if you like . Its about 15 degrees warmer here in Charleston (still only 35 today).
By the way - which lake are you on Larry? Old Hickory or Percy Priest? My niece and her husband live in/near Hendersonville.
