I have a 10.8 International. Trying to locate the drain lines for both front and back units. The back unit in under the fly bridge console and when I run the rear unit it drips from the ceiling vents in the cabin. I also would like to eliminate the draining into the bilge.
Please help
Air/Heat Units
where would you like it to drain into? The bilge seems to me the best place
TIKI III
1985 F32
270 Crusaders
Wet and happy
1985 F32
270 Crusaders
Wet and happy
a/c drain
hy my name is bill I have a 10 meter fly bridge . the salon a/c drain may be pluged take down the cover that holds the 3 vents look for the drain hose not the freon hoses the hose runs on the back side of the air handler let me no how you make out Bill
run them in to a attwood bilge/head drain box then pump it over the side,
If you really don't want the condensation to go into the bilge you can use one of these "http://www.mmair.com/marine_division/ac ... ondensator" it sends the condensation overboard with the seawater.
AndyF32 wrote:If you really don't want the condensation to go into the bilge you can use one of these http://www.mmair.com/marine_division/ac ... ondensator it sends the condensation overboard with the seawater.
Andy Leave the " Out next time your link will work. Or even better put a space before and after the link and then you can use ".
Trojan
