Wire Penetrations In New Hard Top
Posted: Thu Apr 22, 2010 8:48 am
by Molly Too
Ok, I've outsmarted myself. I got this nice new hardtop with the radar mounted on it. Does anyone have any suggestions for a watertight cable penetration system? The through hole needs to be 1†and the cable is about ½â€. There’s no way to connect pipe to the dome so the cable will have to be straped to the top and exposed on the topside.
Posted: Thu Apr 22, 2010 12:20 pm
Mel I belive west marine has want you need I will try and find it online
if you can email me a photo of what you have may help if its not set up like I think .
Posted: Thu Apr 22, 2010 6:26 pm
by captainmaniac
Would have to see what you are trying to do to know for sure, but I have used (on a smaller scale - for a VHF cable, and for loud hailer wiring) a clam shell vent... Drill the main hole, run the wire, bed a clam shell vent over top of the wire and hole (opening facing aft of course), and shmoosh as much silicon or caulk of your choice in to any gaps between the wire and the vent to seal off the back end.
Posted: Thu Apr 22, 2010 9:38 pm
Mel I belive this is what your looking for
http://www.westmarine.com/webapp/wcs/st ... /0/0?N=377 710&Ne=0&Ntt=blue sea&Ntk=Primary Search&Ntx=mode matchallpartial&Nao=0&Ns=0&keyword=blue sea&isLTokenURL=true&storeNum=5003&subdeptNum=3&classNum=30
Posted: Fri Apr 23, 2010 6:35 am
by foofer b
How about a big huge glob of 4200 caulk.
