Replacing fuel tanks on an F-28
pnmudge
Post by pnmudge »
Hey guys
Anyone replaced the fuel tanks on an F-28 yet? The tanks are on my mind, as ours are original 1976. They look fine on the outside, but know it could be a different story on the inside. Not leaking yet, but would rather replace before that happens.
Wondering if I'll have to cut open the cabin floor, or if they'll fit up through the hatch openings...
Thanks for your help!
F-28 1976
twin 318 Chrysler
willietrojan
Post by willietrojan »
I have a dock neighbor who has an F28 and I know what the engine room looks like, so I would say it would be better to remove the engines than to cut-up the deck.
Spanish Fort, Al
Looking for 33 International
Post by larryeddington »
I am rehabing an F28 and intent to replace the fuel tanks most likely. As yet I have not tackled that one. I do not know fi they will fit throug door or not. A thought might be able to get them out of one of the rear windows if it were to be removed.
I intend to use plastics if I replace at the same time I am putting two fresh engines in. I do not see any way of the tanks coming out via engine rome without removing aft bulkhead. The tanks in the engineroom are the water tanks.
Keep us posted on your trials and tribulations as will I.
Larry
yzf195
Post by yzf195 »
As larry says the fuel tanks are forward of the bulk head on my f-28 the tanks in the rear are water tanks. Larry who did u have haul your boat to your house ? I am doing engines and transmissions at the end of the season and wanna do it at my house.
1978 Trojan F28 "lakehaus"
2010 Glastron GX225
boat hauling
I will give you a call this evening and talk about, as it is kinda complicated, but I brough mine down from Cleveland, a bit farther than you need.
I will call you this evening after 7PM
Larry
