is it possible totrailer a 26 troyan
Posted: Sat Aug 19, 2006 11:57 am
by zandunga 28
can i fit a troyan on a trailer and pull it over i am going to buy one and want to trailer the boat to mexico any coments welcome
Posted: Fri Aug 10, 2007 12:21 am
by Eric T
I recently moved a 25' trojan marlin on a 3 axil trailer from the florida keys to Michigan without any problems. Make shure your trailer is rated for the weight you are going to be pulling. make shure you inspect /replace/repack the bearings and races before your trip and I would take along a hub kit or 2 and all the tools and jacks you would need to do roadside repairs
Posted: Fri Aug 10, 2007 9:43 am
by briansselectautos
I keep my f24 on a trailer and it tows quite nice, however weight seems to go exponentialy with lenghth so, as long as your truck and trailer are up to it its no sweat! There's a 26 ft searay just down the road from me on a 2 axle trailer and it looks comfortable. I'm sure yours will too.
Posted: Wed Aug 22, 2007 12:10 pm
by Hardyw38
I trailer my Trojan F26 a couple of times a year and when I purchsed it I hauled it from Northern Michigan to St louis with out any problems. The only concern that you might have is the rudder hangs low. So I remove mine when I trailer it, Here is a link to pictures of my boat on the trailer.
http://webpages.charter.net/hardyw38/
Hardy
Trailering F26
Posted: Fri Sep 28, 2007 2:12 pm
by jcatkinson
Hardyw38 wrote:I trailer my Trojan F26 a couple of times a year and when I purchsed it I hauled it from Northern Michigan to St louis with out any problems. The only concern that you might have is the rudder hangs low. So I remove mine when I trailer it, Here is a link to pictures of my boat on the trailer.
Hardy
I'm currently paying $300 per month on berth fees for my F26 that I very seldom use so I'd like to pick up a trailer for her and was wondering if I should go with a double or triple axle. How difficult is it to remove the rudder? Since the beam is 10' will I need a permit for transport? I'm located in CA.
Thank You!
26' Express
Posted: Fri Sep 28, 2007 8:46 pm
by jcatkinson
Forgot to ask if anyone knows what the weight of the 26' Express is
Posted: Sat Sep 29, 2007 9:51 am
by Trojan26NC
I have my 26 on a triple axle trailer. I think the weight is about 6500lbs with some gear on the boat.
