FRONT WINDOWS F25
Posted: Tue Jun 01, 2010 1:09 pm
Hi all,
I'm on my way to the marina after posting this, to remove one of the front windows of the cabin. The windows leak because the rubber seal that goes around the rim are dry rotted, and all corners are missing causing major leaking.
After removing the windows, one at a time, then remove window from frame, clean up the frame and repaint. On the boat, I want to clean up all sealant that was added around the edges, sand and repaint, white.
I then want to apply window shade tinting, (black) so very little light will get through.
Now here is my problem,,,,,,resealing the window back into the frame. I doubt if I will be able to get the original rubber seal to install, unless I pay an arm and a leg for it, if I did find it?
So, I thought, who better to ask about how to do it, than you all.
My thoughts are,,,apply a sealant to bottom edge of the frame, then place window inside frame.
After that, use a paintable sealant on the outside of the frame, smoothing it at an angle, as one would in a home window.
After that, I can tape off around edges of the sealant and paint it black, the same as I will the frame.
Does this process sound,,,,sound? Am I missing anything?
Any and all suggestions will be appreciated.
Larry
Larry
