check those fume detectors
Posted: Tue Jun 15, 2010 8:39 am
This is exactly how disasters happen:
I came onto my boat the other day and immediately smelled gas. I went up and turned on my new (less six months) fume detector but it didn't go off. I figured if not now, when?
Opened up the engine bilge and could clearly see gas right around the bilge pump. I know I had some water from the previous rain but it looked and smelled like 5 gallons of gas down there.
Did a quick check around and (fill, vent... hoping because I got gas the day before) and they were dry. Damn...
Then I realized my worst nightmare, a leaking tank. I was walking around in a daze thinking my season is done, where do I even start with a problem like this, etc.
The guy at the end of my dock is pretty mechanically inclined so I asked him to come down to confirm my worst fear. We looked around and could see a trail of gas but couldn't actually see the leak.
He left and I just sat there wondering what to do next. I could hear a "drip, drip" and found the stb fuel canister filter has gas pouring out around the fitting. What a great feeling to know it was an easy fix.
The previous owner replaced one of the brass fittings but it wasn't for a flare connection. It "fit" but the flare end of the line never really sealed. Once I got the correct one I could immediately see it, problem solved.
I then called Xintex about the fume detector. Long story short, it looks like I have a new/defective sensor. You can test them by taking a lighter and cupping your hand around it and let some of the butane out. It should go off in about 15 seconds. I had another new sensor and did this back to back with the other one and it never went off.
They asked me to send the old sensor back to have them determine why it didn't work. I think I might have caught this problem the day before if the sensor tripped. The scary part was the detector looked normal and never gave any indication that the sensor was bad which it's supposed to do.
