Macerator pump went...
DaddysGirls
Post by DaddysGirls »
I have an 81 F32 & it appears my macerator has taken a dump, lol... Anyone ever replace one? Was it a difficukt job, what kind of macerator did u use to replace it?
LandVF36
Post by LandVF36 »
Messy, but not hard. Get the PN off the old one and order the replacement before start (you don't want to mess up 2 days of your summer with this project).
Current Fleet:
2000 Carver 450 Voyager
1994 Scout 15'
2005 Caribe LCX9 dingy
1981 16' Hobicat
It a easy fix if you have a few fix it skills,witch we all need with old boats. You should be able to get from the sight or a marine supply store its most unbolt it and install.
sehord
Post by sehord »
Very easy to change, all inlet and outlet connections are the same, and you probably just have hose clamps connecting the two hoses. Two wires to remove and attach and your set. BEFORE YOU BEGIN>>>> look at the rear of your motor on your current pump. THere should be a rubber cover in the middle. Pop it off and turn the screw with a screw driver. This will clear any clogs that may lock up the motor and make you think that it is bad... it just may save you $150 on a new pump.....
A ship in a harbor is safe.... But that's not what ships were built for
k9th
Post by k9th »
Good advice Sehord and I agree, it shouldn't be too hard.
Tim
"SeaDog"
1979 36' Tri-Cabin
mytrojan
Post by mytrojan »
Not hard to replace. Get numbers off the old one and West Marine has sale on macerators.
On mine I can pull the plug on the back off and there is a straight slot screwdriver hole where you can turn the drive. Do you have one? Many times mine gets jammed from the kids and it is able to be freed up. Just a thought.....
1971 SeaVoyager 36 "Scallywag"
wowzer52
Post by wowzer52 »
Also, after not being used for a long time the impeller blades will stick to the housing and make you think it is bad and by turning that screw backwards will free them up. Been there, done that.
1975 F-32 "SIMPLY BLESSED"
