Fuel Filter part #??
Posted: Mon Jul 26, 2010 5:22 pm
by sealilly
Hello all, I have a 1976 F36 with Chrysler 400's. Just before the carb inlet is a canister fuel filter with threaded ends. I cant seem to find this filter and/or part # anywhere. They appear factory, but you never know. They are connected via a 5/16 flared fuel line. I tried a very comm AcDelco fuel filter GF481 but the fittings are too large, then a GF90 and the fittings are too small. This filter looks just like the AcDelco fuel filters that I have changed in hundreds of GM vehicles! Anyone know these?
Posted: Mon Jul 26, 2010 5:31 pm
by g36
see the website link below is this what you are looking for? at the bottom of the page.
i have looked at these but was hoping to find some cheaper but havent yet. maybe some else will post if they have
http://www.hurrikain.com/Chrysler-Carbs.htm
Posted: Mon Jul 26, 2010 10:32 pm
by rooferdave
does it have a drain bolt in the middle? My buddy has these in his 318's and they are 5 bucks each, I can get the # off him if you want
Posted: Tue Jul 27, 2010 12:39 pm
by Stripermann2
Does it look like this, number 7? If so, the Chrysler number is 4142597 and available at http://www.marinepartssource.com You may be able to get a Napa dealer to cross reference to another...
Posted: Wed Jul 28, 2010 7:18 am
by g36
$23 from marine parts source and i was thinking $19 was bad from hurrikan
Another solution
Posted: Wed Jul 28, 2010 3:59 pm
by sealilly
Thanks everyone for the help. I emailed Hurrikain about availability. I have found another solution for my situation and thought I would share it. I used a GM fuel filter ($12) and a $2 adapter and it works perfectly. Below is the setup:
AcDelco GF90 fuel filter (long GM # is 5650677)
Edelman #124520 5/16 inverted X 1/8 Inverted brass fitting.
(got these at my local Carquest Auto parts store)
If we/I could find a fitting that was 5/16 inverted on one end, and metric (14mm x 1.5) inverted on the other, then we could use the hugely popular and even cheaper GF481 or GF652 AcDelco fuel filters.
