mid cabin - floscan preliminary results
Posted: Mon Oct 04, 2010 8:38 am
I got my floscans and racors installed and did a quick test run on Saturday. I have an issue with the stb side sensor, the needle is sweeping up/down and I need to troubleshoot. For now, I'm doubling what I get on the port side which seems to work flawlessly. I'm "assuming" the stb side will be the same or close so take these for what they are.
Readings are from Garmin GPS, upgraded trim tabs, roughly 1/2 tank fuel and water, three people.
2,000 RPMS/8.8k/12 gallons/hr
2,300 RPMS/10k/16 gallons/hr
2,900 RPMS/15.7k/26 gallons/hr
3,100 RPMS/17.2k/32 gallons/hr
3,300/18.4k/38 gallons/hr
4,000/22.9k/60 gallons/hr
I didn't really spend any time with the trim tabs so these can be tweaked a little. No surprise, you can see when the secondaries open over the 3,000 mark.
My bottom paint needs to be stripped (lots of layers) so that'll help for next year.
I've gotten to 4,100 WOT. That seems to be about the max on the mid cabin with the original 3 blade props. I think a couple of people have gotten to 4,300 but in the surveys I found on-line some of the higher readings noted about 150 RPM difference in tachometer error.
If you have a mid cabin and are getting around 4,000/4,100 you're pretty close to the top end. In the video that RWS posted they posted 4,100.
CRUISING SPEED (rpm/mph):
3300 / 20.9
TIME ON PLANE: 5.8 seconds
TOP SPEED (rpm/mph):
4100 / 26.8
I'll post some better results once I get the stb side sorted out.... hopefully before the season ends.
3300 / 20.9
4100 / 26.8
