has anyone tryed poly glo
mr elevman
Post by mr elevman »
Seen a few boats after it was on for awhile. They looked yellow
Wes
Post by Wes »
Maybe they were made in China.
BobCT
poly glow
Post by BobCT »
I've read bad things about it, like peeling and yellowing as well. It looks great going on, I've seen it firsthand but ultimately makes a mess.
I also read that mop-n-glow is the same stuff which makes sense.
davidsmith
poly glo
Post by davidsmith »
My F-36 was very chalky. We tried compound and wax, lasted about three months chalk was back. Put 5 coats of Poly Glow on last spring and it still looks like it did the day we put it on. It dosent have the shine that wax does but the chalk has not come back and it is easy to apply. Also very easy to keep the hull clean, nothing seems to stick to it. Going to put one coat on this year.
1977-F36
22`Aquasport
1969 18` Donzi 2+3
g36
Post by g36 »
i use it and have been for the last 3 years. my boat isnt yelllow and there is no peeling at all. i will continue to use it. if you dont put it on according to the instructions then there might be some problem with adhesion but as of yet i have none. i have many complemnets .
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
Re: poly glow
BobCT wrote:I've read bad things about it, like peeling and yellowing as well. It looks great going on, I've seen it firsthand but ultimately makes a mess.
been there, done that on a 22' Grady White.
Looks GREAT for a while.
I was truly impressed.
Once it starts to go, it goes BAD.
Run Away !
Unless you are looking for a quick sale.
rossjo
Re: has anyone tryed poly glo
Post by rossjo »
mr elevman wrote:has anyone tryed poly glo
No.
But I think Paul is experienced with Poly GRIP ....
:wink:
Ross That was low even for you :shock:
I expect that from Tony but you ?? :D
rossjo
Post by rossjo »
Well - from your pix, your(?) teeth look great ... so inquring minds begin to wander ... ;-)
Hey hey! I didn't say a thing about poly-grip , I could've taken shots on this one, the king is gettin cut on because he popped at the all you can buffet :D :D :arrow: is that what you excepted ?
foofer b
Post by foofer b »
Gotta chime in. My super structure was very badly oxidized. I compounded, buffed, waxed and swore and it was still chalky. I put poly glo on my boat three years ago and it still looks great with no recoating. I do store my boat under cover, but most of ya'll do too, at least six months of the year. Dirt does just rinse off
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
risctaker
Post by risctaker »
I was able to spend some time last Fall with a fiberglass restoration pro who does this stuff for a living. He both told me what to do then gave me a demo on a badly oxidized 40 year old FG hull. First he sanded the entire hull with 220 grit in a high-speed orbital sander (the sandpaper does NOT harm the gelcoat). Next apply a liberal amount of 3M heavy duty fiberglass rubbing compound using the same high-speed orbital sander but this time with a heavy buffing pad. Finally finish with a high-quality marine paste wax using a standard power buffer. When done my girlfriend could have applied her makeup in the reflection of the hull.
aka "Basket Case"
383 Chryslers 280 HP V-Drives
Lincoln Harbor Yacht club
Weehawken, NJ
g36
Post by g36 »
sigh
1997 CARVER 405
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
