starter ring continues
g36
Post by g36 »
as you may have been following my saga. the flywheel where the ring gear is worn according to the dude at the machine shop. that was the reason for the roll pins. hes going to tack weld in addition to try holding it there. but suggest finding another flywheel which i have been trying to do with NO success. has anybody got any leads on one?. would appreciate any leads. i have searched online and everybody that lists one when you call they dont have one so thats not working to well so far. thanks for any assistance
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
You can try:
http://www.Marinepartssource.com - 866-388-0390
http://www.marysvillemarine.com - 810-364-7653
Not sure if you'll be able to purchase from Marysville Marine without going through a service dealer...good luck.
One from a 318 truck will work just make sure its the right diameter
have you tried napa ? I would they could over night one
Post by larryeddington »
It has been my experience that the ring gear can be purchased temperately and installed on existing flywheel. there is nothing else to wear out like a clutch flywheel.
Question do they actually have a heavy flywheel or is it just a flex plate as used in auto transmissions?
I will no shortly as I am about to take the trannies off my old engines.
larryeddington wrote:It has been my experience that the ring gear can be purchased temperately and installed on existing flywheel. there is nothing else to wear out like a clutch flywheel.
Larry you can buy the ring gear separately but the fly wheel is worn/damaged from the ring gear coming loose .
and yes it is a heavy flywheel not a flex plate.
g36
Post by g36 »
thanks all for the responses.
big d i had seen those on ebay but the numbers (at least) on the cheaper ones didnt match what i had. anyway the good news is bob here at beacon hooked me up and am now awaiting ups. yesterday at the local clutch place i did have my original ring flipped and tack welded and the roll pins removed his decicion . as i was told it could last 10yrs or could let go the first time i try it. (now theres someone convinced of their work). with that in mind i figured i will wait and get the one from bob save this one if i ever had to use it for whatever reason in the future.
1997 CARVER 405
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
Due to dual engine rebuild, I now have two extra 318 flywheels with good ring gear and shock plates.
The flywheel looks just like a regular flywheel used for standard transimission 318s in cars. In fact the ones in my old engines are still shiney and have the telltale swirl marks from machining to be used with a traditional clutch.
thats becuse they are regular flywheels :D
Well I have two sets, heads one good block and internals, one rev rotation engine all is good but block. Two manifolds 11 degree and. 3 degree both for 4 bbl. Two sets of exhaust manifolds that appear to be good. Engines had 950 hours on them and run but one block iice cracked
