cutlass bearing
Posted: Fri Jun 10, 2011 6:01 pm
by kickervr15s@aol.com
i have a question will a worn cutlass bearing make my boat vibrate has new prop and shaft
Posted: Fri Jun 10, 2011 6:04 pm
by rbcool
I've seen it happen. But if you have a new shaft, maybe thet didn't line things up properly.
Ron
Posted: Fri Jun 10, 2011 6:06 pm
it does have about 1/4 inch of play in it
Posted: Fri Jun 10, 2011 6:08 pm
by rbcool
gezzzzzzzz....... I think you've answered your own question
Ron
Posted: Fri Jun 10, 2011 8:45 pm
by Big D
Will deffinately cause a vibration. Stick in a new bearing, make sure it goes through the center of the stern tube, then check alignment.
Posted: Fri Jun 10, 2011 8:48 pm
kickervr15s@aol.com wrote:it does have about 1/4 inch of play in it
1/4" ??? wow , you no longer have any bearing left it needs to be replaced asap be fore you damage the shaft .
Posted: Sat Jun 11, 2011 4:39 pm
sorry my bad my dad says 1/8 inch of play
Posted: Sat Jun 11, 2011 7:04 pm
Still not good
Change It !!
Posted: Sun Jun 12, 2011 6:30 am
by AbsterMcgee
Just replaced the cutlass in my 30" with the help of the forum.
Very easyily done with the strut removed. What A difference! Also had about an 1/8" wear.
Abster
