FX-1 install - nightmare
Posted: Wed Jun 15, 2011 2:58 pm
I know you guys have installed the Microair FX-1 control panel and box. Has anyone done it on a Lunair unit?
I ordered mine from one of their distributors in TX and have been bouncing back and forth between them and Microair (who does not want to talk to end users). What I've pieced together is the Lunair install requires some bypassing/rewiring in order for it to work. I've got it wired correctly (panel to control box... Microair verified that).
It comes on, pump works and it blows cold air. The problem is that the unit turns on with the breaker and the control panel in the off position.
Apparently, the Coastal Climate version of the FX-1 comes with instructions to do exactly what I need to do but it's not their unit and they won't even sell the directions.
By any chance did anyone get the Coastal Climate FX-1 version and have the step by step to get it working with the Lunair?
I told the distributor what Lunair model I had when I ordered it and he said "no problem". Now I'm saying I need to return it because I can't get it to work and he's saying "that's a problem".
Any help appreciated! I know it's probably 5 mins of wiring if I knew what to do.
