Tri-cabin Salon Windows
k9th
Post by k9th »
Greetings and I hope everyone is having a great summer aboard your Trojan.
I have pretty much finished the inside projects for this year and am moving to the outside of the boat. I noticed that the black coating on the exterior aluminum window frames on the salon windows is wearing off and almost completely gone in some areas. Any suggestions on what is the best thing to use to re-coat these window frames?
Along with that, the former owner apparently at one time had put what appears to be black duct tape partially over the window frame and when I removed it, it left some of the old adhesive and parts of the tape on both the window frame and the fiberglass. I've tried Goo Gone but it is too thin and just runs right off. Any suggestions on what to use to clean this off?
Tim
"SeaDog"
1979 36' Tri-Cabin
JonChristman
Post by JonChristman »
I know this will sound funny, but try easy off oven cleaner. Test it an inconspicous area first of course. It did wonders on my boat fdor getting off some paint and residue from some old stickers.
Jon
Former Owner of F-26 "Tir Nan Og"
and looking for another Trojan
gruhs
Post by gruhs »
Hi Tim, I know what your looking at, mine is the same way. A fresh coat of some kind of black would really "pop" against the white of the boat. Ours has the unpainted aluminum windshield frame which at this age looks pretty tacky but don't know of any paint that would stick to it.
Gary
1977 Trojan Tri-cabin
"Seaweed"
Home port East Chicago, In.
rbcool
Post by rbcool »
Goof Off works perfect on glues, wont touch the oil based paint
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
k9th
Post by k9th »
rbcool wrote:Goof Off works perfect on glues, wont touch the oil based paint
Ron 8)
Thanks Ron. I have never heard of Goof Off. I'm going to give the oven cleaner a shot this weekend if it ever stops raining. Had 2" this morning & calling for 1-2 more this afternoon.
If that doesn't work I'll find some & try it.
Tim
"SeaDog"
1979 36' Tri-Cabin
aaronbocknek
Post by aaronbocknek »
okay, i know this might sound odd, but, take a bit of vaseline and smear it on. it's thick enough so it will not run. let it soak for about 15 minutes then wipe off. for the fiberglass, try a small amount of acetone.
tea tree oil also works.
aaronbocknek@gmail.com
Tim, this will involve more work 'cause you'll have to remove the frames but the only sure long lasting coating that will be maintenance free for years that I'm aware of is to take all the hardware to a metal coatings shop and have it anodized black. It's probably the method originally used.
