Page 1 of 2
F 36 STRUTS
Posted: Sat Apr 21, 2007 1:39 pm
by Buckknekkid
Anyone know a good supplier.. or welder
Posted: Thu Apr 26, 2007 6:33 pm
can't Bob get them ?
Posted: Thu Apr 26, 2007 7:33 pm
by Buckknekkid
I just emailed them
Posted: Fri Apr 27, 2007 9:32 am
by jav
I tried welding mine (f-32) and it would not work due to casting porosity and salt intrusion.
I was able to source new ones from the manufacturer (Buck Algonquin) using the casting number of the side of the strut.
Posted: Fri Apr 27, 2007 11:38 am
by Buckknekkid
I'll try to clean off the anti fouling and find a number
Posted: Thu May 03, 2007 6:58 pm
by Buckknekkid
noop ,, it was welded before and its a bad job..
Beacon comes through
Posted: Thu May 10, 2007 5:35 pm
by Buckknekkid
One call, hull number and UPS shows up at my door... Thanks to the guys at Beacon ,, Ray
Posted: Wed May 16, 2007 3:31 pm
by rossjo
how much?
they arent cheap
Posted: Wed May 16, 2007 6:50 pm
by Buckknekkid
about $950 each, cutlass bearing included, I posted pics on Boat Design .net
Posted: Wed May 16, 2007 7:27 pm
by Buckknekkid
ok click here to view or copy and paste
http://boatdesign.net/forums/showthread ... post140433
notice the size of the 37? Searay beside us. :wink: :wink:
oops a glitch
Posted: Thu May 17, 2007 7:24 pm
by Buckknekkid
Width of supports was different so we had to do a little drilliin and fillin ,, check out this thread again for pics
http://boatdesign.net/forums/showthread.php?t=17339
Broken Strut - 1974 F32
Posted: Tue Aug 05, 2008 1:47 pm
by rossjo
My diver showed up today to clean my bottom, and told me I have a broken strut on my 1974 F32.
Where did you guys find one? What Buck Algonquin casting is it? Who do I call @ Beacon marine?
BUCKNEKKID's new strut was a different "trianguluar" design that looks much stronger. Is this available for tehe F32. If so, I'd have to drill new holes, and fill the old (not trivial).
Sounds like I have a lot of work ahead of me. Any other advice?
:( :( :( :( :( :( :( :( :( :( :( :( :oops: :oops: :oops:
Posted: Tue Aug 05, 2008 5:08 pm
by Buckknekkid
I have an old one in the back yard,,,, hahahaaa Take a lot of measurements,, width, angle, etc. the strut will give you the same location, comes with a cutlass bearing installed and the angles must match. Location holes dont really matter. Use all new hardware!!!!!
F36 struts
Posted: Tue Aug 05, 2008 9:54 pm
by rossjo
Are these "standard" F36 Struts (pix from Buckknekkid's boat on BoatDesign.net) ?????
http://boatdesign.net/forums/attachment ... 1179357763
Posted: Tue Aug 05, 2008 10:09 pm
by mr elevman
i to this year had found a broken strut port side cracked along the bearring jernal found the casting#and one call to marine tech 2 days latter it was on my door mat when i came home 450$ with a new cuttless and new ss mountting hardware
